Why use an old Xacto? What is the benefit as opposed to a new (very sharp) blade?using the old Xacto
sorry. i was using a colloquialism. Of course you must use a very sharp blade. Dull blades lead to cut finger.Why use an old Xacto? What is the benefit as opposed to a new (very sharp) blade?
Hello, who makes this jig pleaseI too, like Brian use a similar tool. I've tried the soldering irons with the adapters and molds and soaking and clamping to the hull. I take a contour tool to get the shape of the hull then "eyeball" transfer it to this tool.
I've found that this tool will handle any bending job I give it.
As far as how well it will do the job really depends on 3 things, thickness of the planking, wood type of the planking and finally the severity of the curve in the ship's bow. Softer woods are more malleable, harder woods less so. I've never had any trouble bending even 90 degrees over a 6-10 cm ever. I have had to soak harder woods longer in hot water, up to 60 minutes. BUT the aspect of this tool that I love is, depending on the width of your planking, you can bend up to 6 planks at once AND it is a passive tool!!! Unlike other planking tools that you have to actively work. Once you put your planks in this tool and wait for them to dry, you can get back to doing other things on your model. I'd rather put 6 planks in this thing and go work on something else for 2 hours than sit there for 2 hours bending planks![]()
Also, if you don't want to wait for them to air dry, you can hit them with a heat gun or hair dryer to speed things up. But I rather let them air dry and work on something else as we all know how monotonous planking can get.
Cheers,
Ken
I am sorry El Capi but I would like to correct a little the difference between chemicals structures composition of wood.finally I found some pic. of the struktures- do not go to much into chemical problems. only that the 3 huge bio. products make a 3-dimensional structure. I general said to the student that is like building a house. The Glucose is the single brick, which together with the help of concrete-hemicellulose are glued together. The lignins are Stell or very Strong pillars which avoid that with the 1Th storm everything crashed
Thanks for your comments. We both more and less agree on the most. I did not want to do it to chemicals.I am sorry El Capi but I would like to correct a little the difference between chemicals structures composition of wood.
I do not explained that since a long time, so I am hoping to be precise enough... and not to much too.
- Cellulose : cristalline frame, the skeleton. Give flexibility strongness and other properties to wood. More White the material is, less hemicellulose and lignin are in it.
- Hemicellulose : semi-cristalline, so disrupt the ordonnance of the cellulose fibers and therfore affect the cellulose by lowering his propertie (in general), or increasing it by obtaining more felxible structure, that make sens since it became less cristalline. BUT, flexibility is not the only properties of wood's fiber.
- Lignin : considered by pulp & paper specialists and chemists as the glue between fibers. It alter a lot the structurale properties and the behaviour under chemical and mechanical treaments. Soft temperature treament allows to increase the flexibility of the fiber for a moment, so it is done when planking the hull. This is why mechanical treatment are done under 70-90 Celsius. Above 105 Celsius, the lignin begin to flow over the wood inherent structure and lead to the manufacturing of composite woodden structure as one example. Cheap wood material for construction are also made like this and recognized by the clear presence of chip in the board which tend to be brown.
Dear Michel, Yes - although retired now for 10 Years I have been working for words biggest enzyme producer "Novozymes Denmark" I have made trials with Pulp& paper in Portugal, but I mostly used enzymes in the Brewing and Alcohol Industries and Fruit Juices. We had a special Enzyme, which can destroy the Alfa 1: 6 links, and thereby get s amylose, for a much better fermentationYeah, I know them. I worked on oxidizes nanocellulose on PHd project to allows antibodies attachment for bacterial detection. Kruger are able to produce industrial nanocellulose and I think they use acidic condition to obtained it. FInally, the project deviated to podiatric treatment putting a protein that I can not speak about here in fiber matrix for antibiotical or antifungical bandage. This work has been done by my master degree's partner.
Are you in the pulp and paper field El Capi or chemical industries ? I was resercher chemist and teacher in this field, particularly in recycling and flottation process, environnmental process and wet end chemistry. Now I am retired.
Michel
I come from the mining industry. I am very familiar with differential froth flotation of sulphide minerals. Did you ever work with James Finch out of McGill University?We live in really a small world. Thanks for your presentation. May be a last point of interest : my principal work in recycling was in the developpement of and industrial technological transfer from mines to paper industries in the flottaion of ink instead of mineral. I was part of a consortiumwhich included an european compagny near you as Kvaerner, Norway.
I stop here, I do not want to hijack the thread. But there is a great community here.
I forget to specified Cominco, from where came the original technologies. I alors wrote the only original french book in the field:I come from the mining industry. I am very familiar with differential froth flotation of sulphide minerals. Did you ever work with James Finch out of McGill University?
If you don"t mind me asking, where did you get that iron? I have been looking for that exact type for a long time. The ones I had from modelshipways don"t last more than 1 year.Here’s what I use to bend, the Sapelly is very hard to bend, it worked great. I made another block on the clamp on thing to go hands free
Thanks. I'll look to see if I can order it.It’s an old aeropiccola brand bender that is no longer produced, you can find them on eBay every once in a while. They do work well, and when it burns out you can adapt the head to a soldering iron tip - that’s what I did anyway… https://www.ebay.com/itm/393905802071?hash=item5bb69d8b57:g:1~0AAOSwY89h9kEK
This one is a good deal, I’ve seen them go for a lot more! Better hurry!
