- Feb 10, 2022
First a quick introduction.
I'm getting back into making models since being a teenager and before life and work got in the way. Now I've retired I'm picking up this hobby again.
I only made plastic kits before. But before I jump into HMS Victory i need to see if I can get my hands to do what I want them too.
So brought my self this cheap Chinese kit (GBP £11.00) of the Halcon scale 1/100. the idea being in need to start slowly with something that doesn't matter if it ends up as firewood but hopefully learn some technics and good practices along the way.
1st Impressions is the kit is pretty poor and instructions are rubbish but the laser cut seems accurate.
I haven't brought the accessories for it so I will be attempting to turn the square cannons etc. round.
Pics of progress so far.
Above Laser cut bits
Above Poor instructions
Bulkheads fitted. Took the extra step/precaution of adding some scrap wood to make mast boxes, they have been drilled out to take the masts.
just thought this addition would give a bit of a better more secure fit.
Above deck, gunwales and rail fitted didn't to soak the gunwale used a score/cut on the inside to help with the bend.
in hindsight soaking then bending would have been better
Above pics after a bit of stain (more for protection at this point).
Not sure of the finish I want at the moment leaning towards using just stains and varnish.
the above pictures show another addition as i started to plank decided wasn't happy with the strength of the bond between the planks and the bow and stern so added a filler of scrap wood between the bulkhead's and bow stern/transom.
As I start to add the next rows of planks I'm thinking I'm going to need to use filler so the Idea of a stained and varnished hull is probably going to be painted.
