Glad Tidings Pinky by DUncan - Model Shipways - 1:24 Scale
Greeneville TN usa
Well, it just arrived. I am very excited. This is going to be a challenge for me. I have read a lot of build logs and my conclusion is, when I finish this build, I will have learned much about model ship building. It look like only half of those that started this build acturally finish.
First question: how do you flatten out the plans?
wish you luck and fun building this model
we will try to help and assist as much as possible
plans: usually ironing is helping already
This is called laying the keel.
I cut the rabbets before attaching the sternpost, keel and stem. I’m going to wait to taper the sternpost and stem until both halves are are glued together. The stem taper is a little more then just a taper.
I’m going to try to stay away from the CA glue with this model. That means things will progress more slowly. (From what I learn from other build logs is the “pros” use yellow or white glue most or the time. )
Looks like you are upping your game after the MBLS. I've no doubt you're up to the challenge. Will be watching with interest.
Out of curiosity, did you order this from Model Expo or is it a vintage release from EvilBay?
Looks good.
EBay can be fine. Just like most places “let the buyer beware”. I love eBay when I’m buying, hate it when I’m selling.
I love Model Shipways. I'm currently doing the 1799 32 gun frigate 5/64" scale. I've never seen this model before. It looks really nice. I'm eager to follow your success! Have fun!!
Magic Mike
I took my ship plans and went to a copy and print shop and they were able to make 1:1 copies of the prints. The original prints were folded back up and saved while the copies became the working plans. It can be hard to make accurate measurements with a dividers across folds that won't lay flat. The other option is to get the prints laminated, but then you can't scribble notes and changes on the plans.
You can also take them to a graphics shop and have them vacuum mounted to a piece of foam core. Shouldn't cost much to do and then you're all set to frame them if you want.
As much as copying the original. If they are actually creased (as in, folded, vice simply rolled up) I don't think anything will completely eliminate that, but even if you try to copy the original, that distortion is going to be in the copy as well.
Making a copy using the large copy machine the printers had left only the faintest indication of where the folds were, and zero distortion. Perhaps making a copy, then painting over and whitening any lines that might appear, then recopying it again could make a really nice poster worthy of mounting. Or, a digital scan could be cleaned of unwanted lines and reprinted.
Thanks for all the suggestions about the plans.
I am working on the starboard half of the hull. Almost have all the bulkheads glued in place. Not using CA makes the job much longer.
I’m thinking about the next phase, planking. I’ve been watching the Russian lady’s build log. She used pins to hold the planks in place. What is she using for glue? And why don’t the pins split the planks?
I’ll post some pictures soon.
Olha Batchvarov tends to use PVA glue, probably because it is flexible where CA is brittle. I try to use PVA as much as I can because in the long term (decades later), that flexibility means things won't pop apart. Bending rigging that was secured using CA will break the fibers in the line overtime. It may be faster, but it may also darken wood by soaking into it like a sponge and hardening. As far as pins go, use Fine 10mm pins made by Amati and you won't split planks, even in hardwood like walnut, in most joints. Any other pins are larger and more likely to crack wood. In first layer planking, you can pull the pins out leaving minimal hole size or drive the pins in and submerge the heads in the wood plank over them later in the final planking. Sometimes tool like these thin pins made the difference between success in holding a joint and doing damage. They don't tell you these tricks in kit instructions. That's why we have this forum. Thumbsup
Thanks. I checked Amati. They have everything I could want and more but they must be in Europe. The shipping must be a problem. Is there a US company with the variety that Amati has?
Starboard side bulkheads are all glued in place. I need to add the blocks between the bulkheads. I’ll do that while I wait for the port side bulkheads to dry.
The plans suggest that each hull half can be planked, then glued together later. I can see an advantage of doing each half separately. It looks like it would be easier the hold the hull while bending and fitting the planks. Any suggestions?
I ran into a problem with the port side stem half piece. The radias was wrong. No even close to the starboard side piece. I will let you know my solution if it works.
Remember test and check such things as opposite sides with this kind of build.
One issue I have with eBay is you often get older versions of current kits, an they aren't what you might have expected if you looked at the manufactures website.
Be vary careful if buying kits that have been started or the seller can't confirm all items are there, I have been burned, but it is a buyer beware sales platform.
