You mentioned earlier about maybe using a hair dryer. I found that a curling iron used after soaking works great. My wife had one that was about to be deep-six'd, so I salvaged it. Much cheaper than an electric blank bending tool.
Hey. How did you attach the rudder hinges?Interesting. I completed La Nina with many disasters, mistakes and OMG's. I found the instructions confusing so had to do a lot of head scratching etc. (Also I'm not the brightest candle on the cake). I look forward to your progress on this model. BTW I backed Prada![]()
Thanks. I will try this.Hi Hutch. Not too sure what your rudder issue is but what I did was drill the holes then cut the nails so they would fit into the same drill hole from either side but placed a suspicion of extra slow super glue gel to hold the cut off nails . Hope that is an answer for you. cheers.
It is the 8220. A bit more up market than necessary but hey. Better to over engineer things.Hey ConsNZ. I bought a battery powered one. Am in hospital at the mo. Just had surgery for cancer in the armpit so out of action for a While.
Will get back to you in a few days when I get home.
