     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Hello Uwe,Looking very good
I have one question related to the wall itself.
It seems, that these vertical boards are not single boards, but one solid sheet with some milled or scratched vertical lines.
How do you make this? Is it pear?
Hello Uwe,
I take the tool from Trumpeter and scribe a joint with it every 3 mm with the help of a parallel scriber. Please read Post#102. All walls are made of pear.
Greetings
Lucius
Dear RüdigerHello Everybody,
The first deck beams for the quarterdeck were installed. The gratings, capstan and companionway are also finished.
to be continued.
Greetiungs
Rüdiger
No, I don't do that. It is a slightly darker pear wood. Paint twice with "Clou Schnellschliff Grundierung" and polish with steel wool. That's enough.superb detail, accuracy, realism and workmanship!! Thank you for sharing your skills and techniques.
Are you staining the window/door frames? If so, is it an oil or some kind of stain/sealant?
