I am happy for you that you finally received the kit, Brian. In my conversations with Da Hai, he has made it clear that the goalposts are being shifted with this kit. Judging by the packaging, the appearance of the wood and the jigs it certainly looks like something very different. I do believe however, that the acid test of this kit will be when the perceived quality is measured against the purchase price. On the surface all looks very good, but very expensive. Therefore, the question will be how expensive - people like to judge against known parameters and in doing so will ask the age-old question: If it is double the price of Model XXX, is it twice as good?
I will follow with interest. I just hope that you don't make us wait as long as with the Granado.![]()
I believe that some things needs to be simplified to cut the cost,as this is a prototype build the final version may not be the same including the jig accessoriesI tought the same thing when I saw for the first time the all metal building slip on Aliexpress at a couples of x100$. All these money just for an accessories.
Being a “fixture” guy I love the fixtures and jigs.The kit has an optional extra of reusable building jigs and a threaded cast aluminium building base to lock everything in place. This is a really unique and wonderful idea and could be used on other ship models with minor modification.
.View attachment 315831View attachment 315832View attachment 315834View attachment 315835
Good morning Brian, if it is permissible, what material is the Kit, I see it very refined, ThanksI have started to glue together the keel and stem structure. All pieces fit perfectly together like a jigsaw puzzle.
This is a real pleasure to assemble, with barely any sanding or filing required.
.View attachment 316428View attachment 316429View attachment 316430
Good morning Heinrick, Thank you, see mailFrank, if I may answer on Brian's behalf - it is called Yellow Tang wood - a Chinese species of fine wood.
