MIKE DAVE CAN YOU SHOW A LITTLE MORE OF THE HISTORY OF THE FRAMING WITH SOME 3-D AND EVEN ME I AM GETTING VERY, VERY INTEESTED IN THE REASEARCH IF IT IS NOT TO TIME CONSUMING, MABE OF INTEREST TO OTHERS. GOD BLESS STAY SAFE YOU AND YOURS DON
one reason the blocks and frame stack so well is the smooth accuracy of the laser cut
look at the block i built by cutting out by hand all the frame parts
you looking very close just looking at the block in your hand it looks pretty good. but still there is the introduction of had cut vs laser cut.
HelloBonjour,
Bravo pour cette réalisation et les photos, qui aide beaucoup pour mieux comprendre les différentes étapes de la construction !
Ok thanks Mike41 for the translation! personally I use the automatic translator, it's simple and fastOk merci Mike41 pour la traduction ! perso je me sers du traducteur automatique, c'est simple et rapidecar je ne parle pas Anglais ! :Oops:
sorry, look for something on Spanish Architecture regarding GalleonsMike and I were using a Spanish shipwreck as a source of framing information but we were building and English ship.
from Scheepvaart museum in Amsterdam the illustration shows the same type of framing so we can assume it was used as a standard method through out shipyards in Europe. It also shows the early framing of Admiralty models was not just a modeling style but an actual framing method.
I only allowed myself a thought of mine is nothing morehey nice work on the hull, partner, i got to get moving here to catch up.
using the term "partner" as like minded people or group with the same goal. In this case build a model. Now to call yourself partners is to agree with what each one is doing and i must say Mike has this under control i have nothing to disagree with.
It's a good idea to use magnets to assemble parts!C'est une bonne idée d'utiliser les aimants pour assembler des pièces !
