Thank you, my friend! The first plank has been laid, but it is the one that basically follows the deck line, so the filler blocks were only partially used. The next one will be the first oak plank and then I will be able to see whether the blocks do their thing. I sincerely hope that cannons are firmly fixed, Jan - once the next deck goes on, it is game over as far as access to them is concerned. Yes, the planks were left for 15 min in lukewarm water, after which the K-plank bender did its job perfectly!What great job, the hull looks spectacular. I like the way you installed the cannons, they look firmly “entrenched” in place. I assume you used the “K” iron after a good soaking to bend the oak plank.
Hello Paul. I think my pictures may be misleading - they are normal thickness (or at least what I regard as normal), 1.5mm. Even so, the solid and stable surface on which to plank was exactly what I was after.I don't think I realized how thin the planking is on your single planked hull. Care in providing a stable and solid surface to plank to is very wise (confession: I doubted the need for all the fillers...now standing corrected).
Bending oak.....And to all the prophets of doom who said that bending oak is going to be difficult ... easy as pie!![]()
Thank you, my friend. The cannons came out very nicely. Now I just have to hope that they stay that way.Outstanding work my friend, and i love those canons peeping out of your stern.
A job well done![]()
Yes, I remember you posting this before. That is simply amazing work, Phil and beautifully finished!
Thank you, my friend. I am just as happy that I am at the planking stage which is one of the marked differences with the previous build.Good to see you arrived at this stage: the planking! Time pays out now, Heinrich.
Thank you very much for the kind words, Ken - I appreciate it very much. The first oak plank is done, the pins and clamps have been removed and it is looking very good. I will post some pictures once the second wale plank has been laid.Heinrich, Looking at your port side, your hull looks perfectly smooth following great lines and no defects. Super job. I can hope my next hull will "fares" as good as yours.![]()
Hi Johan. I know I am a strange one, but I really enjoy the planking. This is to me where the real challenge of model shipbuilding lies and the fact that it is only a single layer, adds a dimension of immediacy to the whole process. I concur 100% that it is absolutely wonderful to be able to do this uninterrupted.This really looks like monk's work to me, plus nerve wrecking. It's a good thing you can focus on this stage of your build, without disruptions from having to teach.![]()
Hi Heinrich, Is the lower hull single or double planked? You have done such a good job fairing it I would think one layer would be enough. Well done. JJ.Good morning, everyone. This is for all my friends have who have been so patiently and anxiously waiting for the first oak plank to go on. (Thank you for the pressure, @GrantTyler Grant - it keeps me sharp and on my toes.)
It does take time and lots of clips and clamps, but ...
the end result, I believe, is well worth it. The oak plank in the middle is flanked by the two walnut planks which will be doubled to form the wales. Notice the ever so slight "lip" as indicated by the two red arrows. (@Pathfinder65 Jan, this is why I do not as a rule bevel planks. When I dab that lip with my 360-grit sandpaper, I will have an absolutely perfect layer of planking which will be 100% even.) The contrast in color between the oak and the walnut was exactly what I was after and I am very happy with that effect.
