Yes, you are quite right Heinrich, if you start it, you have to finish it, i found that out as well by saying as little iron as possible on the Hermione, now i have the consequenses as wel.
But no vacuum and TV?? is this out of principle?? or do you have another reason?
All my floors are tiled or wooden, Peter - no carpets; so ordinarily, a vacuum cleaner is not really necessary. There are only two English channels on Chinese TV, unless of course I subscribe to international networks. I have just never felt the need to do that.
I understand completely Heinrich, and what you don't have, you don't mis.
Hello Everyone
So, here I am with the results of Day Two. The starboard side has been finished and the bow fillers on the starboard side have also been completed.
I am very happy with the curvature of the hull on the starboard side - it follows the fairing pattern, perfectly, so that is all good!
Secondly, I have also managed to make some good progress on the Port Side.
There is still a LOT of work to do, but I am making progress.
She is looking great sofar Heinrich, and nice progress on the sanding
Thank you, my friend. The starboard side really looks good, and I am happy with the lines. Now I just have to do the same on Port Side. When everything is done, the hull will get a complete sanding with 240-grit sandpaper, and I will finish off with 360-grit. Friday is still the goal!
When my power goes out it’s time for a nap.
Off Topic chuckle. We had a generator installed years ago (1999) because the constant power fluctuations back then. When the Electrician was laying out the circuits he asked the Admiral what were the most important circuits that should be wired to the generator panel. There were three that she noted as very important, #1) the well pump (water), #2) the furnace (hot water) and #3) the outlet in the Master Bath (Hairdryer). The generator got a good break-in run a week later running continuously for 107 hours due to massive Rain/Ice storm that coated tree limbs across the state with up to two inches of ice.
Hello Everyone.
After 5 meters of Paulownia went into the little ship this is what she looks like tonight. I have yet to do the stern and the bow, but I will first sand the rest of the hull and then box those sections last when I have a clear line of the hull shape.
Viewed from above there aren't too many tell-tale signs of what is going on beneath the waterline.
But flipped over - you can see the full effect.
Somewhere in there, there is a beautiful woman waiting to be unleashed! ROTF
For their expedition ships, Dutch shipwrights of the sixteenth century, favored a relatively squared hull. ROTF
Boy, you're a man with way too much spare time on his his hand.
I probably missed something in the last kazillion pages of this build, but why on earth do you use the Lego approach on your entire hull? For the highly convex areas of bow and stern I can understand, but for the other, more benign curvaceous parts of the fuselage I'm not sure what benefits are.
Good, question, as always, Johan - I will attempt to answer you.
1. Strictly speaking, I can build the hull without any FILLER blocks - as I have done with my previous build where fillers were only used for Bulkheads #1-3. It is thus well within my ability. BUT - I planked that with walnut and this will be with oak. I have never worked with oak before - I do not know how it bends, how it holds its shape and what percentage of spring back it has once all forms of clamps/pins and the like are removed. Instead of only giving myself the gluing area afforded by the bulkheads, I have chosen to go for planks that I can glue and secure along the entire length of the hull.
2. You mentioned "curvaceous". If you look at this picture below, you will see that the hull follows an acute curve from Bulkheads #1- 8. It is only after the planking wraps around Bulkhead #8, that it follows a relatively straight line to the stern. if I have filled between the first b bulkheads, I may as well include numbers #9 and 10.
3. All possibilities of indentations, kinks or dips in the planking are completely eliminated. Remember, I do not have the luxury of a double-planked hull - I get one shot and that is that.
4. It adds an enormous amount of rigidity to the whole model and also makes the upper ends of the bulkheads (from where they extend above the deck upwards) much more solid. This also means greater accuracy when planking above deck level.
5. This is basically similar to the authentic, bread-and-butter style building, pioneered by some very famous and yet to be emulated old-school Russian builders. I have always wanted to try this method (I regularly advise others to follow this method) and regarded it as personal challenge to incorporate on this model.
6. I have a two months' summer break now, so I do have some time (you are right, probably too much) on my hands. ROTF
Love it Jan, of course the hairdryer needed to be included in the list of three essentials! Thumbsup
Ha Heinrich,
Thanks so much for your extended answer.
To me the most appealing reason is the extra bond area you're adding, taking into consideration the unknown properties of oak, it actually makes a lot of sense.
Also, if done well, and I don't have any doubts whatsoever that you do, you end up with a very smooth and even surface to which to attach your planks.
The bread and butter challenge..., hmm, not quite sure what to think about that. I have no experience with that method, other than what I've read on SOS and I'm not really comfortable with that method. I did shape the blocks, fwd of frame 1 of my Bluenose and I can't say I'm enthusiastic about it, since you're basically lacking any reference, but that might be caused by being inexperienced.
But since you're on a well deserved holiday break, you might as well spend that free time pleasantly ammused.
Cheers,
Johan
Ha Heinrich,
Cheers,
Johan
No problem my friend. During the holiday period, I have no face-to-face communication with anyone - except for the times the Admiral visit. My days, and sleepless nights (as was the case tonight) are spent in my own company. To keep sane, I might just as well be doing something.
Ha Heinrich,
Cheers,
Johan
Thank you for asking the question Johan and thank you for the excellent explanation Heinrich.
I was wondering this myself but was too scared to ask Redfaceas I am pretty sure the answer would have been somewhere back in this log that I probably missed.
It's an absolute pleasure my friend, but please don't be afraid to ask. The little I know, I share gladly.
Hi Heinrich, on occasion when our electric power goes down it never fails to amaze me how dependent on it we are. No power tools whatsoever, only manual tools can be used.
Ah Daniel... on occasion...now I know why I have no power tools- e.g yesterday the power here was out 430-630am, 12-2pm and 10-12pm. Redface. I think I now know why Heinrich doesn’t use power tools- he had his ship building apprenticeship here in SAROTF. Cheers Grant
