- Jan 9, 2020
Daniel, I tell you - if I had known this beforehand, I would never have done it!Wow Heinrich! Almost 11 hours at sanding, you must have used up quite a few sheets of sandpaper as well as cups of coffee.
Sanding tools. That is 80-grit and Paulownia is supposed to be a "soft" wood. Well, these ones are on steroids. And you are right, there is even an inner of a toilet roll for the curves.
The graveyard.
I would guesstimate I am probably 25-30% percent done.
Hi Ken. It is called Paulownia wood which is supposed to be more or less an equivalent of balsa. However, in reality, it is much, much denser and therefore sands a lot more difficult too. I am working on these forearms - and an anchor tattoo may be an excellent idea!
