Royal Louis 1/200 Heller
Cross Jack Yard
I've already made one a year ago, but looking on it now it's ugly. New one is from 4x4 pear strip. Job is pretty easy, but it took me some material to make one which didn't break
I've tried to make a more complex version with "faked" middle part and better edges. That didn't go so well. Maybe if material was thicker it would work, but it kept shaking and I couldn't make straight line
3.07.22 Update.
I've placed Cross-Jack yard, Mizen top sail yard and Mizzen topgalant. Only Mizzen yard and Spritsail-yard left to put. After finishing with yards only tackles and some back stays will be left to take care:). I also realised I need a smal ship to work on when I'm weary of repetitiveness in L'Ocean. Thus there's option for another heller ship:)
Another thing I've noticed. These pulleys look so funny compared to yards. Like big head with small bodyROTF. I knew it before that they were too big, but now when I looked through so many real ships it's soo wierd and funny
You made a very good job on the rigging of the bowsprit. Thumbsup
On the last photo I realized the total length of the mizzen yard, which is looking very long, maybe too long comparing with the contemporary drawing
DSC_0271.JPG Dessin-p-pujet-supposc3a9-reprc3a9sentc3a9-le-royal-louis-16692.jpg
The rigging is finished. There're only port lids to add, but there's to little of them and for now I don't know what I'll do with them.
It's likely this's the last update.I hope you like it, despite my mistakes big and little. Ther's so much potential in this little ships you just have to know where to look for upgrades and extras. Most of my elements is oversized, but I think does not interfere with the view.
Hallo Wojtas, ich finde, sie seiht richtig schön aus. Eine Frage zur Takelage habe ich; hast du hier den Takelagenplan von Mamoli genommen und auch dabei geblieben oder hast du einen anderen Takelagenplan benutzt? Vielen Dank für deine Antwort und Grüße Günter
Hello @GIG23
Thank you for appreciation. Yes I used Mamoli plans as a reference. I only changed bowsprit and anchor rigging. See post #27 and #8.
I also used little too big deadeyes they should be 2mm and 1,5mm(or 1,5mm hollow ring). I hope this answer satisfies you, good luck with your build.
Google translate
Vielen Dank für die Anerkennung. Ja, ich habe Mamoli-Pläne als Referenz verwendet. Ich habe nur Bugspriet und Ankertakelage geändert. Siehe Beitrag Nr. 27 und Nr. 8.Ich habe auch etwas zu große Jungfern verwendet, sie sollten 2 mm und 1,5 mm groß sein (oder 1,5 mm Hohlring). Ich hoffe, diese Antwort stellt Sie zufrieden, viel Glück beim Bau
She's a beautiful ship and you are doing a great job! My only issue concerns the armament. The lower gundeck typically holds the 32 to 40 pounders, the next deck up typically holds the 24 pounders, while the next one typically holds the 12 pounders. Please note that I am speaking of English ships, but the French followed that trend in their own fashion.
Bill
Yes. It's too long for sure. I took heller's yards as a patern. When I flipped it, it was reaching near main mast
But it's very close to Musée national de la Marine model
There is a chart on pages 216 and 217 that you can use to determine the proportions of masts and topmasts in relation to scale in Wolfram du Mondfeld's Historic Ship Models. It is a tremendous help!
Bill
Bill
This ship is basically finished beyond repair after kitty hurricane came through. As for the ship itself, if I were to build it again the list of things to change would be much longer then just one yard.
