Build log USF Confederacy 1778 Model Shipways 1:64 [COMPLETED BUILD]
Hello modelers,
in the past weeks I have been busy with building, but not before today I took the latest pictures which I would like to show. The planking of the quarterdeck is finished, and the quarterdeck fittings like the speaking tube, the steering wheel, the binnacles, the coamings etc. are in progress. There is still a lot of work to do.....
Greetings
Werner
Hello modelers,
Greetings
Werner
Dear Werner
Wow it's looks beautiful, you are doing wonderful work and accurate
Hello modelers,
Greetings
Werner
Sehr nett.
Hello modelers,
Greetings
Werner
A truly outstanding model.
Superb work, Werner. Your whole deck planking layout and the way in which you display the lower decks is probably one of the best, if not the best I have seen. Exquisite!
Hello Maarten, Heinrich,
Thank you very much for your appreciation. I only did my best to achieve a good result with the provided kit, making some upgrades (brass cannons instead of the metal cast cannons, gun port hinges and the blocks for the gun tackles). I used only the provided basswood although it is very soft, but it can be easily sanded and lengthened exactly with a sanding tool.
