Dear Friends
I said to
@GrantTyler Grant earlier that I hope to place an update tonight and here it is.
Have saw, will build!
Even though I broke all my knives yesterday, I called my little saw into action. I used a Stanley knife to score the sawing line and the saw did the rest. The unworldly mess in the upper left-hand corner of the picture, is the rear hatch (re-do) under construction. Sometimes, I think that my fellow builders on SOS will cringe if they have to see my methods.
In any case, out of the mess in the first picture came one rear hatch that I am very pleased with. The red lines indicate the position of the half lap-joints while the yellow lines indicate just how careful you have to be with the woodgrain. Those woodgrain lines can really be confusing when filing and cutting the planks straight.
The main grating (ok, the only grating) came out very well. Once again, the red lines indicate the half lap-joints.
View from the bow towards the stern.
View from the Starboard Side towards the Port Side. These pictures of the rear hatch and the grating are super macro close-ups, and I remain happy. Moreover, they are now done the way they should be - none of these fancy 45-degree mitered joints!
I have also brought the rear bulwarks up to their required height. As you can see, I am still waiting on the glue to dry so no sanding or finishing has taken place. While planking the bulwarks, Frame 8 finally decided to cry enough and inserting the push pin, it broke. Bear in mind though that this was the frame that I had cut in half to accommodate the gunport. Seeing that this is the last plank for which the frames will be used (after this, they all get cut away) it did its job.
@Pathfinder65 Jan, with this in mind, I do have a recommendation for you.
With the advantage of hindsight, I would rather follow this configuration. In this instance, you would have to cut part from Frame 5 away but seeing that all planking for which Frame 5 was required, has already been done, it has served its purpose. Rather keep Frame 8 intact which will be needed for the planking of the upper bulwarks!
