Like you showed in this photo it was correct how the frame elements have to be positionedHelp. I have now got on to frames6,7,8. These are the first ones that need sanding to a profile/sanding lines. So, take the "lower" 3 parts ( left & right, and a center piece that joins the previous 2) all 3 have lines etched on them. Thing is, how do you glue them together? do the edges go together and then you sand to a line, but doing that you lose one of the etched lines. Or, do you glue them so that the center piece touches the etched line of the 2 parts? as in photo. Just want tyo make sure before I go any further.
Oh NUTS!!!!!!!!!!!!!! I asked Victor how to do this and think I may have interpreted his answer wrong. I have ended up putting the 2 layers on top of each other, with the edges flush, with the etched marks facing out. I did do 3 the way you have shown, but that didnt seem to work out either. I am now up to frame 15, with all edges flush.Like you showed in this photo it was correct how the frame elements have to be positioned
I tried to make a sketch showing a tcpical double frame
green are the two framw element, so f.e. two futtocks
red are the laser lines on the elements
blue are the final edges of the finished sanded frame, when you follow the red laser marked sanding lines
I hope, that I did not misinterprete your photoOh NUTS!!!!!!!!!!!!!! I asked Victor how to do this and think I may have interpreted his answer wrong. I have ended up putting the 2 layers on top of each other, with the edges flush, with the etched marks facing out. I did do 3 the way you have shown, but that didnt seem to work out either. I am now up to frame 15, with all edges flush.
Hello Uwek, thank you for taking the time to help. I am now pretty sure that the lower of your sketches is the correct way. However I shall proceed with caution and check a bit more carefully in future.I hope, that I did not misinterprete your photo
You have to check this with the drawings where the sanding lines are also shown.
Check the width of parts and compare with the lines on the drawings
The top or the lower system
On the top the parts are smaller and have usually on both sides the laser lines
On the bottom they are wider and have only on one side a laser line
I haven't found any such jig, however I did knock one up for myself, just a piece of scrap the right thickness to suit the keel. It just lines up the center and the 2 Left & Right sectionsHi Colin, I have been watching you log and have been wondering if a small stepped jig the same width as the slot in the frame that fits into the keel came with your kit? There should be a rise of about 2mm. If so then you would put the 'b' frame in the lower part of the slot and the 'a' frame in the higher section, at least that is how it works with MSD'S Blandford kit. Hard to explain but these pic's might help.
View attachment 328646View attachment 328647View attachment 328648
I have been putting the sections with both etched sides facing out so that they can be sanded to the visible fairing lines. Cheers JJ..
Greetings Tom, We would like to see the progress of your Hoy assembly in a build log. How about that? Is it feasible? Thank you in advance,Good work BTW. Mine is also of the 'could do better' but I'm persevering with it.
So which bit do you use?Hi Colin, I am a bit ahead of you and when it came to profiling those bow and stern 1/2 frames, I bought this from Amazon. It feels like it's built as well as the much more expensive Dremel cordless. It made light work of the sanding but you will need to get lots of the largest sanding drums and a box of face masks 'cos it don't half make a lot of dust.
SabreCut CraftMate SCMG002UK Lithium Ion 10.8v Cordless Rotary Tool Multipurpose with 42 Accessories Included
Cheers
I didn't use a drill bit, just the sanding drums. I know exactly what you mean by 'aggressive' - especially the 80 and 120 grits but I've found some 240's which are a lot less evil.So which bit do you use?
I haver a selection of "mini" drum sanders but found them to be rather aggressive, care needed. I learnt (or didn't) the hard way. ! slightly mullered frame!
As for new mini drill I am looking at the Proxxen. I have had many "cheap" mini drills and they have all not been too good.
Hi Jim, you do realise that I'm the worlds worst when it comes to remembering to take photos and post updates? I will though, start a build log soon - and cross fingers I keep it up to date.Greetings Tom, We would like to see the progress of your Hoy assembly in a build log. How about that? Is it feasible? Thank you in advance,
many thanks for accepting the offer, but don't worry if you forget to post in a timely manner, we will remind youHi Jim, you do realise that I'm the worlds worst when it comes to remembering to take photos and post updates? I will though, start a build log soon - and cross fingers I keep it up to date.![]()
Cheers
