- Jan 9, 2020
Dear Friends
With the inner planking of the front canopy completed and the stanchions placed, the whole assembly was stained with the CLOU. Then it was time for a test-fitting of the frames. I expected to pick up some issues here as I built the ship wider than the Kolderstok version, but a little fiddle here and there and all looks good!
What should be clear from these pictures is that the canopy is much more integrated with the hull and also follows the curvature of the whole ship much better than on WB#1.
As another indication of how much wider this ship is than the previous one, I test-fitted Hans's scratch-built winch at the front of the canopy! Those of you who follow the build regularly, will know that on WB#1 it was impossible to fit the winch and belaying rack in front of the canopy, but in this case - just look at all the space!
If I move the winch (which incidentally is much bigger than the original Kolderstok version) fractionally back towards the cabin, I can easily fit a belaying rack in front of it. I will in all likelihood stick to my position underneath the canopy, but it is nice to know that I have options.
And by leaving the front canopy open, even the bigger of the two lifeboats has ample space!
