Hello Friends
The stanchions between the two canopies have all been trimmed to size and, strictly speaking, I can now be forming and shaping the two top railings that need to go on.
But then it dawned upon me that IF I am going to fit a front wall of the center canopy, I have to do it BEFORE the top railing goes on. The reason is that the top railing will extend all the way to where the front wall would be. (See picture above).
And that brings me to my dilemma. To front wall or not!
On his build,
@Ab Hoving Ab has made provision for two doors, but at this point the doors had not yet been placed - or so it would seem. Interestingly, the front wall has been planked vertically and not with the overlapping (schotelende) planks as I have by now become used to on Dutch ships.
His plans show the same configuration, but here it becomes obvious that no doors were used. In his drawings of the captain's cabin, Ab pertinently shows the doors, so we can assume it is no omission here. No why you would create a front wall, create the openings for two doors and then not place them - especially in a bitterly cold polar climate, is beyond my understanding.
Secondly, we have De Weerdt's interpretation where he has left out the front wall completely and the whole structure remains open.
Thirdly, we have the
@Kolderstok version which has a closed front wall AND two doors installed (exactly like I have built it on WB#1.
Now with all due respect to my learned friends, theirs are interpretations (as is my build), so I turned to what has become my favorite and the only original source - the drawings of Gerrit De Veer. Unfortunately, in this instance, the drawings are also contradictory.
On this drawing you will see a multitude of very closely grouped vertical lines in the red block which indicate an opening - thus a left-open front wall a la Gerald De Weerdt/replica.
While my favorite drawing clearly shows a closed structure with a single, arched door opening, but no door.
So, in summary, I have the following options:
Front wall left completely open.
Front wall with two door openings but no doors.
Front wall with two door openings and two doors.
Front wall with single door opening, but no door.
Which one would you guys go for?
