Ok I was just curious about thatThe drawings are marked 1:1. But I will check more accurate.
Change the fit for parts number 5, this error was in the first serial sets.I am assembling the jig and have a problem with assembled parts 5 and 6 lining up with the holes in parts 4 and 3. I could modify the parts to fit but don’t want to make a mistake. Did you have this problem?
Good morning. I have enjoyed your build process so far and,while I have not built a Pavel kit, I am a huge fan of their construction process. Looking forward to you receiving your new planks and continuing. Cheers GrantGood that the problem got a solution. Now it's just a matter of waiting for the new planking.
Hello, you are welcome to follow the construction. I think it will be fun to build a Viking ship.Good morning. I have enjoyed your build process so far and,while I have not built a Pavel kit, I am a huge fan of their construction process. Looking forward to you receiving your new planks and continuing. Cheers Grant
You did an excellent job on the oar handles. I just started mine. Would appreciate it if you could explain the process you used. Thank youMany oars on this ship. View attachment 348556
Hello ! No big deal. Holds against a disc sander and slowly spins the oar between the fingers. But you have to be light-handed, otherwise there will be nothing left of the oar. It can be good to use a well-used sandpaperYou did an excellent job on the oar handles. I just started mine. Would appreciate it if you could explain the process you used. Thank you
Thank you very muchHello ! No big deal. Holds against a disc sander and slowly spins the oar between the fingers. But you have to be light-handed, otherwise there will be nothing left of the oar. It can be good to use a well-used sandpaper
Hi, I'm also building the drakkar and I won't hide from you that I'm having some difficulties because the manual doesn't quite explain how to proceed in assembling the various parts. I wanted to ask, do the rounded ends of the keel need to be tapered before applying the decorative mask? Could you post some pictures where you can see everything? I would also be interested in seeing how the central frame should be machined and assembled. Thank youIt looks like there is a miss on the jig. There is not enough space for the bow and stern. I solved it by taking out a cut in the jig. Then there was no problem.View attachment 348759
