That is correct for a real ship, however depending on the scale of the model, and how much work you are willing to do, it is often done as I showed. Up to the modeler. ;)
Hi Dean. Totally agree. I have seen models doing it authentically and it is superb. One also has to consider the style of all the previous rigging. I learnt as a rookie that attempting to rig 100% accurately at scale is almost impossible (some guys do pull it off tho) and I kept a style running though from start to finish- certainly not historically accurate. Heinrich has a secret weapon with Anna tho so who knows ;) . Cheers Grant
Oooh the admiral will enjoy that! ROTF Seriously though, the ratlines will be done as per the @Kolderstok instruction manual. So far, I have stuck to the rigging instructions, and it has paid off handsomely - so, no "fixing" something that ain't broken. :)
@Frank48 Frank, this is the same as yours - am I correct?
Oooh l'ammiraglio si divertirà! ROTF Scherzi a parte, le ratline verranno eseguite secondo il manuale di istruzioni di @Kolderstok. Finora, mi sono attenuto alle istruzioni per il rigging, e ha dato i suoi frutti, quindi, niente "riparazione" di qualcosa che non è rotto.:)
@Frank48 Frank, questo è uguale al tuo - ho ragione?
Hello Enrico, Yes, Congratulations to your flagship
Hi Enrico, just for information
Thank you very much, Frank. I will simulate the above by doing it like in the Kolderstok manual. Doing it exactly like in the picture above, is going to be almost impossible. At the narrowest point of the main shrouds, the total distance between the two outer lines is only 7mm.
Hello Heinrich, I thoroughly enjoyed your summation to date on the WB. You have brought a 425-year-old ship to life in my mind.
Now I am truly humbled, Daniel! If I had managed to do that, I am truly glad that I have persevered. At times, there were moments that I seriously doubted the "wisdom" of pursuing what seemed to be an impossible quest, but your comment has validated everything! Thank you for that, my friend!
I agree. She is taking the rigging very seriously and is a stickler for detail. She has already told me though that the next build has to be in a considerably bigger scale so that I wouldn't need her help and could do everything myself! ROTF
Hmm. You can paddle a kayak on your own - but its more fun with a friend. Just saying...
I absolutely agree, Paul. It is so nice to have someone to share the whole process with. That lends a dimension to the build that I wouldn't change for anything in the world.
