Excellent work Peter, at the moment I am busy with Le Rochefort and I am doing similar to you. I also glue my paper very close together to only have to make one cut, it saves time, wood and saw blades.
I really like the reference board, but that is a LOT of parts to cut out !I finally managed to get all the templates for the aft section of EURALUS peeled and stuck to the appropriate thickness cherry planks. I have also managed to get the reference board cut, drilled and mounted to the building board. Some weeks to do at each end is all that remains but I can get onto frame assembly and dry fitting to the keel now.
Yep,I really like the reference board, but that is a LOT of parts to cut out !
frame already finished? Thank youOk so framing is moving along at about 1 frame station a day. I think this will pick up as I'm working on the aft can't frames at present with F31A glued in a F31F ready to bevel the deadwood join. The chocks are a little more complicated then I originally thought as the bevel on the forward face differs to that on the aft face so a lot of careful fitting up with files is need to get the right fit.
Each cant frame station eg F31A has a port and starboard. It’s not until F24A that I start full framesframe already finished? Thank you
Hi Peter, sorry I can not understand (translation) Thank you for answering me.FrankEach cant frame station eg F31A has a port and starboard. It’s not until F24A that I start full frames
F31A means Frame31Aft. Each numbered station has a forward and Aft frame connected at the chock/floor however this doesn’t strictly apply to the cant frames.
Not sure the explanation helps
I was guessing at what you meant by your question. Perhaps the translation didn’t help. Please feel free to use your parent language and I will try another translator programHi Peter, sorry I can not understand (translation) Thank you for answering me.Frank
I feel your pain with double sided tape. Have you looked at Elmer's rubber cement? I used it for all my templates on frames. Comes with a brush inside the lid and you simply paint it on the timber then press the template down. Stays on as long as you want and then peels off easily.Wow, 2 days and I managed to print and cut out all the aft frame templates and get about 1/5 onto timber ready to saw.
I guess this is the tedious part of fully framed model ships... that and trying to peal off the backing on the self adhesive label material.....
Next job is to sort the templates into the appropriate material thickness piles before working out the best way to fit on the Cherry material.
Jigsaw arrived this afternoon so I will charge it and then cut out the reference board.
Great thing you found it when you did rather than after it cured !Ah, Disaster.
Realised I was aligning the foot of the frames at the deadwood to the wrong frame line (1/2 frame out). It appears I failed to taper both sides the foot of frames at Station 31A&F and 30A&F on the starboard side. I managed to remove 30A and 30F with little damage the foot of the frames or the deadwood thanks to a very sharp thin blade and the fact the glue had not full cured.
I am in the process of cleaning up the feet to the right taper on both sides and then check the alignment at the deadwood as well as the reference line.
Lesson:
Need to work out a sequence to make sure all the parts are cut, assembled with chocks, tree nailed, pre-faired then tapered before removing the template and cleaning up the frame for installation. I recall that Talley Ho had one of those check off boards on the wall of the workshop to make sure all the frames went through all the stages of preparation prior to installation.
Well I am back to where I left off before discovering the issue with the starboard can't frames. I have done some further fairing by hand held sandpaper to see that the alignment is true on the inside. If it's right on the inside, the small extra on the outside should fair in nicely. I picked up the issue when I noticed that Frames 30A and 30F albeit correctly aligned on the reference board, were not vertical as they rose above the reference board. The way I have the building board position, I get a perfect view of the port frames but only a side on view of the starboard frames so I will need to move the trolley out into more open space when fitting the frames to get a better view from all angles.
