I think I’ll try that first. Maybe some polyurethane, oil, and amber shellac on different sections of the back.Maybe a little stain on the deck will reduce the visibility of the swirls? Try an experiment on the back..
I used the provided decking. I used 2.5MM deadeyes for the standing rigging. I purchached 1.5MM blocks for the rigging. I used wire to produce the upper shroud spreaders.How fun! Did you do your own planking? They also don’t have real deadeyes, just pieces of metal cast to look like them.
I've got some small blocks I've used for gun rigging, but nothing THAT small. I also don't see how thread can fit into that small a block.I used the provided decking. I used 2.5MM deadeyes for the standing rigging. I purchached 1.5MM blocks for the rigging. I used wire to produce the upper shroud spreaders.
Anything else would be WAY out of scale.I ordered .016mm thread from Blue Jacket and blocks from Dry-Dock featured on this site. I also did the same for the Scientific model Cutty Sark.
"ameliorated" - had to look that one up in the DictionaryWell, I’ve tried polyurethane and amber shellac to see either of them ameliorated the look of the burl/ swirls in the wood. Neither fixed it, but the shellac did a better job of hiding it. In fact, the poly made it worse. View attachment 360054
And I have no idea how to make planks thinner than a toothpick (1.8 mm) in a consistent manner with the tools I have. I think I’ll go with the shellac. The Admiral thinks the deck will be covered with stuff anyway.
Ouch. Shaping the hull was harder than I expected, but it turned out nicer than I thought it would. It would have been murder without power tools. I used a Ryobi sander on the hull and a scroll saw to cut out the stem and rudder pieces.My first kit was the Phantom, Pilot Boat, a solid hull kit, and probably my last solid hull kit, I hated all the extra work to get the hull shaped and my mentor at the time said just cut off the bulkward and lay the deck all the way across the top and then he showed me how to build new bulkward to install on the ship.
It actually has more rigging than my Billing Connie which is much larger than this one!what is so cool about this model is the leech lines which were not included in the 1987 model I have. If you look up the original sail plan for this ship it includes an upper spanker sail " never used" and a mizzen main sail "never used". It also explains the different types of material and thickness of each section of the sails.
Sorry, I used to teach AP English back in the day."ameliorated" - had to look that one up in the Dictionary![]()
