Happy Birthday!
They are actually. I used them a lot to keep certain parts in placeYour deck pins look a awfull lot like my finger stick pins for checking blood sugar.
I like the idea of a kingsplank.ja ja - sometimes every micrometer is counting
often the (real) ships had in the center a wider plank, the so called Kings-plank
Maybe it is an idea to adjust the planks left and right of the center line in such a way, that you can install one kingsplank with a continous width from stern to stem.
Maybe with the 4mm material or even slightly wider
This is the Goodwin anatomy decksplan of the Granado, not showing such a kingsplank. But you can see, that he interpret the deck planking using wider planks between the mortar boxes. But definitely good to know, that the width of the deck planking rows varied based on technical compulsory points or availability of planking in the yards
The smaller decks had no real structural function, so there was no need for a kingsplank, but you can try to make this planking similar to the main deckToday i put in the kings-planks sand the model and put on a very tiny layer if varnish.
@Uwek
On the 2 other decks is there also a kings-plank ?
I want to know because they have a darker color and i think it looks nice when it i also put them on the other decks. On the front and rear of the model.
Then you have a really straight line over the complete model from stern to stem
Well done and great recovery Sir. Cheers JJ..After removing the 2nd layer above the wale and cleaning it, I applied the inner edge at 10 gunports.
This is done with a strip of walnut 1x4 mm. I'm not doing the front and the 2 rear gunports of each side yet.
Once this is done I re-applied the 2nd layer of planking above the wale, the one I had to remove.
The planking will now be on the edge that I applied to the gunports.
After this I applied the same edge to the 6 gunports that I had skipped, only this one is 1mm inward.
So now I have 10 gunports without lids and 6 with lids.
I immediately painted the gunports and the inner bulkward patterns red ochre.
View attachment 363205View attachment 363206View attachment 363207View attachment 363208View attachment 363209View attachment 363210
Then started making the spirketting and the sheer rail.
For the spirketting I bent 2x a strip of 1x7 mm and tru dry fitting i made sure it is the good size.
This i also immediately painted red ochre and placed them when they where dry.
The spirketting is now on his place at the model and the sheer rail is almost ready.
View attachment 363212View attachment 363213View attachment 363214View attachment 363215
For the sheer rail i bent 2x a strip of 10x1mm and dry fit it to make sure it fits the way i want. The bottom edge of the sheer rail i paint it now because otherwise it would be difficult for me to reach it after placement. It needs to dry now before I can install it.
