Sorry for the delayDanke für die lieben Geburtstgswünsche!
Thanks for your birthday wishes!
Cheers, Alexander
also all the Best und Alles Alles Gute von meiner Seite
Cheers, Alexander
The dogs are ready. But they are still a bit fat. Like golden retrievers. I want to go back there and trim them more towards greyhounds.
Thanks Dockattner and to the LikersWonderful work Alexander!
A hole was drilled in the center of the flattened profile using a simple jig.
A 3 mm circle was drawn around the hole with a drawing template and this was filed out.
Because the hammering made the material hard and easily breakable, I softened the material again using a gas torch and quenching in water. Then the part was bent and finished.
Ergonomy Is a quite recent science. The main stair in my old mansion in Piemonte, Italy, built in the XVII century, has got some 35 cm steps or so... and so steeply as well... .Hallo Alexander,
the stairs are looking very good, I have only doubts about the height of the individual steps - there are only 5 steps to reach the next level. So it would be appr. 35cm in real - not very comfortable
Is this also like in the original contemporary model?
Incidentally, in the meantime I have also redone the ramps on the railing. This time the parts are planed, then softened with ammonia, and then shaped. The result is slightly better.
