Hi Waldemar,.
Adminitrators, can I ask you to increase the resolution of the inserted images? Also for non-registered (not logged in) people. Around 1600 dpi for bitmap widths would be ideal. What do you guys think about this?
Hi Olga,What a coincidence!
That we too have been working on this projekt since 2018. My husband Dr. Kroum Batchvarov - Professor of Underwater Ship Archaeologi and me. It really isn’t Naseby... We did photogrammetry with high resolution photos to make a 3D model. Now I am working on the lines drawings, while my husband is writing the research part!
The deadrise on the model most definitely was intended to be there! There is no room for doubt there. It is part of the design feature, there are explanations in contemporary treatises how to do this.Let us not delve into the performance comparison of specially designed ships with high deadrise (or we will end up discussing Symonds and Forfait, which is totally out of scope here).
What I meant to say is that there was (I am not sure how common, but it certainly existed) a method of adding deadrise to, let's say, otherwise traditional designs specifically to increase performance, which may have been proposed by Sheldon as one of the modifications to the design he brought from England during the design phase of the Riskäpplet, and so it is possible the deadrise we see on the model is intended to be there. This may, by the way, account for discrepancies in depth-in-hold measurements in some way.
We actually did use a camera and videoed the interior of the model, yes.Possibly @fred.hocker could shed light on whether there are any known drawings, photos of the interior or x-rays/magnetic resonance imaging (mri) of the model that could be shared. If so I would imagine it would help your analysis significantly. He may have more available information given the access he has had to the model.
And, the simplest explanation, as Fred pointed out, the model was found in three separate pieces. I believe the unevenness of the frames as assembled now, is thanks to that. I have not seen any evidence for "sanding" or any other deformation caused by the builder of the model, Sheldon himself. There is no evidence for two different designs mixed in the same model, either. There is evidence of relocating the cheeks (which currently are a modern addition - beginning of the 20th c) and the hawse holes. As I said elsewhere, this model sat in Fred Hocker's office for years and more specifically on my own desk while I worked there. I had the opportunity to observe it directly; not via scans or 3D models. Thus, I am quite sure that the deadrise is original feature of the model.@Allegheny ,
Please take a look here:
This is definitely a trace of rough treatment of the frames and since it is very different from one frame to the other. Furthermore, do not forget that on the real ship the frames are covered in planking, and it would negate any small differences.
Also take into account that most probably this model was a working model, involved in discussions of the ship's design, not a decorative one.
There indeed are models that did represent two variants of a design on different sides, but by general convention, they have those sides distinctly and differently decorated. The difference we observe on the model is more consistent with shrinking wood than anything else.
This is exactly what we do together with @AdmiralBenbowHi Olga,
Great to hear this info, will you be publishing this research? All this info will make a great book for all our libraries.
However, there just isn't any evidence to support identifying the model as Naseby and lots to identify it with Rijks Applet.
This has absolutely nothing to do with the depth in hold measurement, as that is taken in the hold
