Hello Oliver, This looks great!
Where did you get that guy standing left of your frames?
Did you carve it by yourself?
Hi Dieter,Hello Oliver, This looks great!
I’m continuing to work on the keel assembly and dry fitting the frame floors to make sure they all fit correctly.
While doing that I have also been following @Tobias and @Nersch discussion about the caulking between the keel members and the planking. Per GD the correct caulking for the period was pine resin impregnated hemp which is a reddish brown color. I haven’t been able to locate any reddish brown tissue paper so I did complete a sample with dark grey tissue paper. (The photo makes it look blue…)
I then finished my sample with Osmo Satin Oil.
It’s hard to tell but the end result seems to have a reddish tint to it.
At any rate, this is what I plan to use. My question though is whether you think the caulking is thick enough? I used a single layer of tissue which is about 0.35mm. Thanks again for all your help.
Sorry Dieter, I miss typed the thickness. My tissue paper is 0.035mm.Hello OliverF,
My tissue paper has a thickness of 0.04 mm. Does your paper really have a thickness of 0.35 mm?
Thanks Bill.Hello Oliver,
I feel your pain. It is frustrating to put a lot of effort into making a piece only to have it break or splinter. I am sure you will be able to make the repairs. Moving forward, I will be very interested in see how the cherry continues to works for you. I just ordered a lot of cherry for an upcoming build.
Also, your build is coming along great and looks beautiful.
Bill
