Love itThanks to everyone for visiting my diary. Progress is slow, but steady…
Here is the finished stem section.
Looking good!I think before I go any further I need to make up the transom timbers.
The transom timbers glued up
And bevelled:
I wish you a full and complete recovery, from my mother's experience I know that it is very, very unpleasant. You are doing a great job!!!Fitting the transom timbers to frame 45 was relatively straightforward in the end.
The frame is 10 mm wide, but has to taper to 5 mm (or thereabouts) at the base. The top timber fitted without any adjustment, but the next timber down required a small adjustment. So I tapered the aft face of the frame starting from just below where the top timber met it straight down to a point at the base.
The next timber down when into place OK, and the bottom two timbers needed a bit more adjustment, but eventually fitted. Here is the result:
I haven’t fixed anything in place yet as there are to filler blocks still to be fitted either side of the deadwood. This will involve some adjustments to the floor timbers.
You are right if you are suspicious about how little time this appears to have taken (for me at least). I have been confined to home with a case of shingles in my left eye (!!). The vision in that eye is very blurred, I can still see OK with my right eye… Fortunately, the worst has passed and there’s no lasting damage, although I will have to take eye drops for a few months.
Work of art Salty. Cheers JJ.JHere is frame 44 and 45 on the keel, together with the transom timbers and filler blocks.
I am reasonably happy with the result. There were a few moments when I thought the worst. There are no modifications to the plans (as vague as they are) and I don’t think there is anything obviously wrong to my eye.
The whole structure is quite fragile, so I have not done anything to it in the way of sanding after assembly. Once incorporated in the rest of the hull, I might do some further refining. There is a small amount of material that could be removed from the top of the filler blocks where they meet frame 44.
I have to say thanks to Uwek and the others who have built this kit and generously posted logs on this forum. It would have been just that much harder without them documenting what they did.
Good morning Salty. Looks perfect to my layman eyes. Beautiful work. Cheers GrantHere is frame 44 and 45 on the keel, together with the transom timbers and filler blocks.
