Good morning. POF models are something else. I only have admiration for you guys who accept this challenge and pull it off. Looking spot on this far. Cheers GrantI feel like I have finished the first stage of La Salamandre now the frames have been glued up.
I didn’t mention it in my first post in this diary, but this is my first model ship. Although I probably should have started something more modest, I have been encouraged by reading about the efforts of others on this forum. I have found the building to be enjoyable to date. From my perspective, patience and persistence are the key.
Posting anything on the internet is also something new and I hope you have found some of it interesting. Most of my photography leaves a bit to be desired, but you get the general idea. I must admit to being somewhat surprised by the number of people who have visited my diary to date.
The next stage is to build the keel.
Good morning Salato, I ask: what do these tracings indicate. FrankThanks to everyone who has been following my progress.
Uwek, your detailed descriptions have helped greatly. If you had a dollar for every time I have visited your log, you would be a rich man…
Frame 45 continued…
The part that caused me some difficulty visualising the end result. The angle created in the previous post does not continue all the way up the frame. Rather it stops after the floor timbers and the futtocks and top timbers maintain a constant distance from those in frame 44 (4 mm or so according to Bourdoit and Berti). This why the sides of the ends of the floor timber are parallel to the keel and not angled at 10 degrees.
I then just built the rest of the frame in the usual way.
One final task was to redraw the bevelling lines.
That is as far as I intend to go at this stage. I know the the frame needs to be thinned, but I want to build the stern post to see how the transom timbers fit before I do anything further.
Frank, the laser marking shows where the frames should be bevelled to create the curves on the outside and inside of the hull. In the picture in your post, the marking shows the bevel for the inside of the hull and there are markings on the other face showing the bevel for the outside. The markings take the guesswork out of bevelling and seem quite accurate, matching the frame plans in Boudriot and Berti’s monograph on La Salamandre.
Hi Salty , Thank you for your reply. FrankFrank, the laser marking shows where the frames should be bevelled to create the curves on the outside and inside of the hull. In the picture in your post, the marking shows the bevel for the inside of the hull and there are markings on the other face showing the bevel for the outside. The markings take the guesswork out of bevelling and seem quite accurate, matching the frame plans in Boudriot and Berti’s monograph on La Salamandre.
I only have the frames glued up, but not yet bevelled, but I hope to start that work quite soon. I will post pictures as I go.
Thanks to everyone for visiting my diary. Progress is slow, but steady…
Here is the finished stem section.View attachment 378278
