Thanks
Ebony has a lot of fat and I feel that the adhesive strength is a little weaker than PVA, but so far it is attached without peeling off.
The thin ebony of the kit was easily bent with an outer plate trowel.
Recently, there are no more soldering irons for outer panels, so many people use the tips of soldering irons for art flowers.
I placed the plastic mortar temporarily, but it looked too cool, so I uploaded it for the time being.
The kit also comes with a metal mortar, but I haven't painted it yet. The metallicity is also well done.
very nice model. Can you see the details through the different layers? As I want to make it in the shipyard under construction, I am afraid not all the inner details can be seen. great work!
There is an exhibition in 10 days, and I'm continuing to make it for the exhibition.
The photo-etched parts are small, bounce off, break, and are difficult to adhere.
Photo-etched parts have nail holes and look cool, but they break easily from the holes.
It is difficult to reproduce the pinle (pin) of the rudder.
I cut a piece of wood and glued it on.
I have been a member of The Rope Osaka for three years.
There will be an exhibition in Osaka from July 16th to 18th.
Although it is incomplete, I plan to exhibit Royal Caroline as well.
Also, I will upload the image of the exhibition.
I used linseed oil in the past, but the structural model is prone to dust and wood chips and is difficult to remove.
Since paraffin is not sticky, dust does not easily stick to it, and by adding heat from the dryer, the dust on the surface dissolves inside and restores the luster.
However, paraffin takes more time than oils.
Some people melt paraffin wax and apply it with a brush, but I use a stick and then melt it with a hair dryer.
I apply it 2-3 times and wipe off excess paraffin when it's melted.
If you apply too much, you will not be able to bond with PVC. (Even if the coating is thin, the adhesive strength will drop slightly.)
Unlike brushes, complex structures cannot be painted, so it is necessary to paint each part.
Use paraffin wax with a melting point of 115°F (48°C).
Materials with a high melting point are difficult to melt.
Thanks for the Info
Members of the association "The Rope" visited also the international convention in Rochefort, France already 5 years ago where I was also invited
So I met some japanese modelers already and were able to see there high quality models
1.st INTERNATIONAL CONVENTION OF MODEL SHIPBUILDING in Rochefort, France - 18.th to 21.st October 2018 1.er Congres International de Modelisme Naval - Rochefort - du 18 au 21 Octobre 2018 What is the idea ? The idea is to select and gather around one hundred quality model shipbuilders coming...
shipsofscale.com
especially the 1:300 model of the HMS Victory built by Etsuro Tsuboi was amazing - he was 82 years and visited the international convention with a group of japanese modelers - as I remember they made a tour through Europe, and basis for the trip was Rochefort..... it was highly interesting to get introduced...
Thanks for the Info
shipsofscale.com
Japanese sailing model enthusiasts are old, and models are mostly dominated by Gundam and figures. Also, young people cannot live without mobile phones, and it seems that they spend most of their time on mobile phones all day long.
The international convention in Rochefort is huge and the works are wonderful.
