- Oct 25, 2022
Ok, was that detail present on the other 1660' ships of the line too?
Hi, Love the project! Could you please tell me where you got the 'Plan de la Chambre de l'Admiral' from?
As i am not long started this build i am wondering if there is a special tool for cutting out these side galleries as I have a dremel and a few other tools or is it just a modellers knife that's needed ?Result of this weekend work on the quarter gallery, still haven't cut myself yet.
Hi GuyHi; if you have an exacto knife, the small one it will do just fine. All you need is to be carefull because the first cuts are easier but as you get to the last ones the gallery piece gets weaker and very flimsy in places like the support ends. Try not to be precise and leave a tiny bit of material at first then slowly scrape the excess after; that will give you a more precise final product. A modellers knife will do the same job provided the blade is new, or almost.....If you want to go as far as piercing the sculpted part on the middle gallery, use a tiny drill mesh and pinch it to a small locking plier, then turn slowly in all the spots you want to get opened up; then use the point of your knife, or exacto ot remove the excess plastic and shape the empty space. It does take some patience and some dexterity, but it is all worth it in the end. You can also carve the designs which were removed from the gallery piece and glue them back on the inside... Then if you feel ok with it, use some thin balsa wood to make the floors inside the galleries and whatever else you wish to show
Why lion heads?Hi Guy
Thanks very much that's the kind of information I was looking for. Yes I have a small Exacto/modellers knife with several excess blades too. I have also purchased a whole load of brass goodies like Fleur de lys and Lion heads which I intend to use to some extent as well on the Gun port Hatches etc..
Btw Your work is absolutely superb mate.
All the best
Rob.
Hi GuyWhy lion heads?)
I only managed to finish one side through all that time because I kept looking for information on what that ship could have looked like in 1671; I ende up making a 105 page document onthe research...I had begun wit the idea of making a 10 page summary))
This is what one side looks like...The document is in French, if you can read French I'll send it to you....
Thank you very much for translating this DarivI don't speak a word of French, but I took the time to translate this as best I could using a translator because it is such a great document. Thanks GuyM!
It took me a while to understand that "herpes" in French means "headrails" in English, not that particularly nasty venereal disease. . .![]()
Just started the Small steps...Hi; if you have an exacto knife, the small one it will do just fine. All you need is to be carefull because the first cuts are easier but as you get to the last ones the gallery piece gets weaker and very flimsy in places like the support ends. Try not to be precise and leave a tiny bit of material at first then slowly scrape the excess after; that will give you a more precise final product. A modellers knife will do the same job provided the blade is new, or almost.....If you want to go as far as piercing the sculpted part on the middle gallery, use a tiny drill mesh and pinch it to a small locking plier, then turn slowly in all the spots you want to get opened up; then use the point of your knife, or exacto ot remove the excess plastic and shape the empty space. It does take some patience and some dexterity, but it is all worth it in the end. You can also carve the designs which were removed from the gallery piece and glue them back on the inside... Then if you feel ok with it, use some thin balsa wood to make the floors inside the galleries and whatever else you wish to show
