The work on rudder continues.. by making a new set of braces, three of them, cut out of a brass plate... 2mm wide. I used just a scalpel and cut probably 10 runs to have strips removed from the plate. I also marked a middle line that will show position for a piece of tube that will hold the pintle. The tube was soldered and then cut into required length. Just easier to maneuver the longer tube, instead just 2mm long, very tiny tube..
After soldering, all material are dumped into degreaser for a few minutes..
Washed under water and dipped into blackening solution.
While blackening is taking its time, I marked the position of braces on the keel side.
Before parts are put in blackening solution I tested fitting on the keel..
And mounted on the ship. Some touch ups are required since I used nails to secure braces to the hull..
Happy modelling..
Happy modelling..
