I once asked a mechanic how much torque to put on a bolt. His answer: "A quarter turn before failure..."The most difficult part for me was the nose and under lip.
You did a great job. Watch out not to overdone. You cut easily a tiny micromilimeter to much and the face expression changes for 100%
Also here: it’s all about the details! Well done, Maarten.Hi Dean,
I directly send him to the plasticsurgean to give him some eyelids and removed some 10th of a microgram of boxwood.
View attachment 390270View attachment 390271View attachment 390272
To give you an idea about size of th eyes I put my smallest 0,5 mm chisel next to it.
I see the style you refer to and it seems almost cartoonish. You have done a great job duplicating that. But I am certain no one would verbally beat you up if you made the eye more realistic and added some eye brows. I call it artistic license.Hi Dean,
Many thanks for your comment, much appreciated. And yes I can still add these being work in progress. But the big eye balls seems to be a typical 17th century carving style, see the batavia yard example.
A carving from Batavia
And a recently recovered 17th century carving from the North Sea
A carving from a fluyt wreck.
And Vasa carvings.
I think I use your advice and make them slightly less pronounced like the Batavia knights head.
Btw if you can draw like that you can certaily carve, it is all bout what is in your mind and bring it to wood or paper. Looking at your drawing you can do it better then me, I am just a marine engineer.
Wonderfull work.
This to me is a definite improvement. Well done! The nostrils in the nose would be a nice touch as well. You can use a tiny hand drill or rat tail file.Hi Dean,
Hi Dean,This to me is a definite improvement. Well done! The nostrils in the nose would be a nice touch as well. You can use a tiny hand drill or rat tail file.
Ps - Of course you have more experience than me at carving, so hope I am not being rhetorical!
Looks great Maarten!The last project on the hoekman is his hair.
This guy has long hair according 17th century fashion.
The hair I cut with different sizes U shaped chisels of 0,5 mm to 0,7 mm.
View attachment 390451View attachment 390452View attachment 390453
Maybe I will add additional curls to his hair, not sure yet.
It’s looking great, Maarten. Some well spended time in your vacation.The first Hoekman is finished except for some brushing and buffing which I will do at home.
The second layer of hair is added and I fine tuned his body to give him more waist. His shoulders are lower and his chest is reduced. The lower and upper consoles will be cut when he is fitted on the ship.
The statue is all cut with chisels except for a slot between his legs and the top of his head which were done with a rotary bit.
See below.
View attachment 390543View attachment 390544View attachment 390545View attachment 390546View attachment 390547
I won t bother you with cutting the second one![]()
Please do bother us with photos of the second one (if this is not too much askI won t bother you with cutting the second one
