Lovely under oil. Bravo!
With the difference between CAF and ancre you mean the pilar on which the riffle is fixed, or?I have started building the small guns. I am deviating from the CAF plan and following the Ancre plans.
Hello Uwe yes I mean the wooden stands on which the cans are mounted. Great that you show your pictures and describe it to see what I meant.With the difference between CAF and ancre you mean the pilar on which the riffle is fixed, or?
In order to show the members these small brass elements, please have a short look on my solution
View attachment 346765 View attachment 346766
in a distance of 5 or maximum 10cm you can recognize these parts, in a normal distance not at all
at the end I will also install these wooden pilars - very good work my friend
So guys, you can't really tell from the CAF drawing if they are wooden posts, but you guys are turning me on so I'm going to replace my pilars with wooden ones.Definitely there were wooden pilars as basis visible in the drawings
Contemporary Drawings
Jean Boudriots Planset
but also CAF is showing something similar - maybe in the manual (which I do not have by hand in moment) is something different shown
Sorry for that - maybe is written by Boudriot in the text in the booklet about the used material .......So guys, you can't really tell from the CAF drawing if they are wooden posts, but you guys are turning me on so I'm going to replace my pilars with wooden ones.![]()
Some beautiful re-do’s Tobias. The metalwork on the pump is looking very nice.Hello everyone,
I have to admit that Adi has infected me a bit and I don't want to leave him alone on the floor. Le Coureur is not quite finished yet and my goal is to finish the deck before the holidays. There are a lot of small construction sites. Since I'm sticking to the plans in the monograph on deck, I've removed the rear mast holder (red circle) and installed the rigging bracket.
Also turned the aft sail pole (sorry I don't know what it's called). I also rebuilt the pumps.
Further updates will follow.
