- Aug 14, 2018
Hi Paul,It seems kind of odd to be posting about sandpaper here - but I have been fairing a POF model in boxwood and this sandpaper is so far superior to anything else I've tried that I thought I should at least share:
3M Pro Grade Precision 9 in. x 11 in. Coarse 80-Grit Sheet Sandpaper (4-Sheets/Pack) SHR80-PGP-4T - The Home Depot
1-Sanding Performance. 3-M Pro Grade Precision Faster Sanding Sheets with enhanced mineral technology resists clogging and sands faster. Fold once and the NO-SLIP GRIP durable backing grips together towww.homedepot.com
This stuff actually cuts into the hard boxwood rather than skidding over the top of it - and seems to have a longer working life as well.
I use the fine version of this paper (220 grit) comes in a roll, does a good job and does seem to last better than others. Over here you can get it from Amazon (there's a surprise) it is quite inexpensive £7 odds for 2.5 m roll. I'll have to give the course stuff a go.
Cheers JJ..
