Thanks Heinrich. Yes she does look very wide and when the hull is cut from the jig a lot of the depth will be gone tooBeautiful interior to that hull, Keith. She is quite a wide ship, isn't she?
Also 3 of the parts are numbered incorrectly, which threw me for a while looking for them.
Hi dhabert. The pieces in question are carlings for the lower deck and are shown on the deck plan in the instruction manual on page 27. DL6 (2 pieces) are DL82 (port and starboard), DL14 (2 pieces) are DL87. Although l made these pieces from some spare 4 mm pearwood strips l had left over from another kit. DL8 l could not find at all, but again l made from 4 mm pearwood strip. DL82 and DL87 can be found on sheet No. 12Hello Keef and congratulations on your progress on this magnificent kit. Can you tell us which are the 3 incorrectly numbered pieces so that we don't have to look for them ...![]()
Hi Cathber. No. lt's just a 35 x 4 x 4 mm strip, easy to make from spare strip, which is hidden under the ship's boiler and won't be seen. You can get away with missing it out completely, it makes no differenceBonjour,
Avez vous contacté le fabriquant pour vous aider a trouver la piéce DL8 ?
Elle doit bien être sur une planche.
Good morning,
Have you contacted the manufacturer to help you find part DL8?
She must be on a board.
A huge THANK YOU, Keef for your quick and precise responseHi dhabert. The pieces in question are carlings for the lower deck and are shown on the deck plan in the instruction manual on page 27. DL6 (2 pieces) are DL82 (port and starboard), DL14 (2 pieces) are DL87. Although l made these pieces from some spare 4 mm pearwood strips l had left over from another kit. DL8 l could not find at all, but again l made from 4 mm pearwood strip. DL82 and DL87 can be found on sheet No. 12
I noticed the same thing. If you're married, I bet you are a great husband!What I really appreciate is that you seem totally unbothered by missing parts, incorrect instructions and labeled parts and the like.
l'll ask my wifeI noticed the same thing. If you're married, I bet you are a great husband!
Thank you very much Heinrich for your interest and support for my build. The issues with the parts have been, at least so far relatively easy to sort out, l still think this is a great kit. l'm sure you're right about the Clou. With what l've seen of Uwek's Granado posts it looks very goodEach time that I check in on your build, I am simply amazed at the rate of your progress. And despite the rate of knots, you deliver outstandingly accurate and neat work. What I really appreciate is that you seem totally unbothered by missing parts, incorrect instructions and labeled parts and the like.
I think you will be most pleased with the results of the Clou.
Hi Cathber. Thank you for your comments and interest in my build log. To get this photo l turned the whole thing on it's side and the effect you see is the light striking the inside of the frames creating the illusion they are filled but they are notBonjour Keef et félicitation pour vos constructions (HMS Blandford, etc...).
J'ai une question concernant cette construction. Je remarque des traces brillantes sur votre chantier entre les couples et le gabarit.
S'agit-il d'un effet d'optique, ou vous avez collé (provisoirement) les couples sur le gabarit pour maintenir les couples à leurs places pour être sur qu'il ne bouge pas lors de l'installation de l'intérieur.
Merci d'avance pour votre réponse
Hello Keef and congratulations on your constructions (HMS Blandford, etc...).
I have a question regarding this build. I notice shiny marks on your site between the torques and the template.
Is this an optical effect, or have you glued (temporarily) the couples to the template to hold the couples in their places to be sure that it does not move during installation from the inside.
Thank you in advance for your answer
Keith, That’s some progress, it just get better each time that I look. KenThick stuff and Deck clamps are now all done and the positioning lugs have been removed allowing the lower deck timbers to be shaped and fitted. Everything fitted exactly as it should. The only problem was the first deck beam nearest the bow (No. 4) was made the wrong way round. l had to re-make the beam so the 2 nicks faced the stern and off-set to the correct side. Not a big problem but l wonder if Trident are aware of this error. Also 3 of the parts are numbered incorrectly, which threw me for a while looking for them. Apart from that, the accuracy of this kit is amazing and l'm really pleased with the progress so far
