I would blacken them after you removed thesingle parts and cleaned themI also received gun carriage PE kit and treated them for use. Nice details and plenty of parts for use
Now to start rigging cannons up!
View attachment 384470View attachment 384471
Hi Kurt, Now having a little time to myself I started to browse some builds and came across yours, I don’t know how I missed it but I’m glad that I picked up on it. It’s not the usual but a little different, I think that you’re doing a terrific job at making and detailing this model, I can see the thought and effort that’s going into it and your log makes for very interesting reading. I’m also learning things from some of the replies that you’re getting, I’m late to the party but I’m now onboard. Ken.Well after many weeks away from the shipyard, I was busy in the Rail Yard working my model trains for a show in Grapevine TX, but I am back on the Command Deck again.
I finished gluing in the waterway strips and decided with the stub mast I would add a boom going aft for just a bit extra detail.
I found a scrap piece of dowel from another project box and tapered it down to about half the original diameter. From 7mm to 3.7mm. Rounded the end and then glued more scraps on to make jaws on forward end.
Now to wait for glue to dry and shape them.
I also started on a ring to go on the stub mast for the boom to sit on.
View attachment 394611View attachment 394612View attachment 394613
Thanks Mike, coming from you is a big complement.Kurt, glad you had a great time in Grapevine, great place! Your work on stub mast looks good. Moving forward! Magic Mike
The model is looking very good.Not much going on. Busy working fence line installing property line fence by daylight after work.
I did get several cannons breech lines installed and connected to eye pins. View attachment 397121
Very effective, Kurt! Dry Dock's deadeyes pass the "closeup" test as well!Ok back at it again. I have started working the lower deadeyes for the mast channel.
I got some black deadeyes from Dry Dock models and then cut up some scrap internet cable wire and stripped plastic shield off the individual wires and died them black.
First deadeye chain plate as test done
View attachment 412643View attachment 412644
