Excellent John.
Excellent John.
great work Jhon, well done![]()
Thank you for the comments and the likes,The clinker build hull of your boats is looking very good - Bravo!
I used boilling water for difficult bending. I soak the wood always for a few hour, but when bending in a sharp curve I use boilling water as an extra.Hi John,
In your experience does the boiling water (as opposed to merely hot, or even room temperature) assist with the bending? I am presently trying to bend much larger stock (2mm x 7mm) with mixed results...
Thank you.
Hi John,
Thank you.
G'day guys, these are only small pieces in a cup with boiled water only need a few minutes, but even with thicker pieces the boiling water helps a lot and of course extra time,I used boilling water for difficult bending. I soak the wood always for a few hour, but when bending in a sharp curve I use boilling water as an extra.
Hi John,View attachment 396472
The fo'c'sle rails were next on the list, I clamped the three pieces of wood together then drilled 4mm holes at the required spacing after I had drilled the first hole I inserted a 4mm dowell to keep the correct spacing,
then I filed out the holes to take the wood uprights these uprights were just over 4mm square, I left a couple of 4mm dowells in place while I squared the first holes then added some pieces of square uprights while I finished the rest of the square holes,
The rails after assembly,
and a couple of pics where they will sit on the model,
another view,
after painting,
and where they will sit after gluing, they look a bit flat across but after they are glued down there will be a slight curvature to them,
You've all been so good with following my build, I feel guilty for not posting on your logs lately, actually for some time now, my Admiral has been having a tough time of it and has been in and out of hospital approx eight times in the last year, but I think there is some light at the end of the tunnel, and I will get around to posting on your logs, i thank and appreciate all of your surport, all the comments and the likes,
best regards John.
