- Mar 1, 2023
Finishing frames continues.
This is the inside of my boat Peggy (see post #35) when she was being built.
She actually has twice as many frames as specified in the plans (the builder thought she was too lightly timbered and added extra), so you can perhaps see how heavily timbered La Salamandre is by comparison (if a comparison between a day sailer and a bomb ketch is possible!?).
The frames were steamed to shape and not sawn as would be the case with a larger vessel. If you look closely at the them, you can see the rivets used to hold the planks. After passing through the plank and frame, the end of the rivet was cut off, a washer was placed over it and it was peened over.
I don’t think I can remember ever seeing this detail in a model. In real life, I imagine the spike/bolt was clenched over a washer which would look very similar. In any event, probably very few were actually visible, but there is food for thought if you were so inclined. Obviously, there would be nothing protruding on the inside if treenails were used.
