Happy Birthday, Salty!
I can relate. Figuring out why two pieces don't fit together can be just as hard as fixing it. My problem is I get impatient and start sanding before I start thinking...guaranteed redo when that happensIt wasn’t so much the fixing the causes of the gap that took so long, but working out why there was a gap in the first place.
this is a common problem------ start sanding before I start thinking......
.Good afternoon Salty. Great modelling. Cheers GrantI am now gluing the frames in place.
I am working my way along the keel in sections from stem to stern. I do a few frames at a time with the keelson temporary fitted to keep everything together. When all frames are in place, I will glue the keelson.
The first couple of sections were relatively straightforward and the last few frames will be a little more complicated, so much so that I might end up doing them one at a time. There is very little space for frames 41, 42 and 43 and they don’t quite sit in the jig as well as the other frames because their outer edges are more horizontal than vertical at the point where they meet the jig.
It’s interesting to compare the slots for the keelson now to the state they were in when I was first finishing the frames (see post #99) - like chalk and cheese.
Is there such a thing as a high-tech clamp?Apologies for the low tech clamps
I think your "Sally" looks great! Salty, you say it all yourself. Many of us are our own harshest critics. That's because we want to do and present our best effort. Disappointment, elation, satisfaction, fear, are all emotional and we know emotion clouds objectivity! In time emotions fade and objectivity becomes clear. That's why when I feel like I've made a mistake, or disappointed in the outcome of a task I've completed, I walk away or work on something else. When I return, most, not always, but most times I realize I was being much too hard on myself.a Salamandre could be more a bit more polished but I think it’s worth persevering with her at this point, but I think it’s worth persevering with her at this point if I am being objective (which probably isn’t always the case)
