Thanks, I'll check out your log in the morning.Dear Jan. If you look at my log, you will see that I encountered exactly the same issue. Yes, I took the bottom sills off.
Good morning Jan. Eish….this could be a problem. Great doors BTW however by removing the lower part your hinges and door handle etc will be out of sync. Murphy has struck@Heinrich, I think I have a wee bit of a problem with the next step.
Do I remove the bottom of the doors to get a better fit under the canopy??
Jan
Yup, I’ve thought about thatGood morning Jan. Eish….this could be a problem. Great doors BTW however by removing the lower part your hinges and door handle etc will be out of sync. Murphy has struck. Cheers Grant
Good morning Jan. It looks like you guys have plenty of clearing to do. That “jungle “ grows pretty rapidly during spring/ summer. Maine certainly (according to google) looks like a beautiful state. I don’t know how you guys do those crazy cold winters but a snowmobile sounds fun so better get those trails readyNot much progress to post. Outside temperatures are in Fall mode and I have the opportunity to do some needed cleanup of our neighborhood snowmobile trails.
Me, getting ready to drag some cut brush to the wood chipper. This a jpg conversion from a short iPhone video. Haven't figured out how to convert the Apple format high resolution video to mp4, etc.
Jan
Hi Grant, the Jungle on that part of our property is a vine/ bush that grows like crazy. Given the amount of rainfall we had this summer there was a lot of growth. I you would believe it we had a three to four year drought so the unusual amount of rain this summer helped immensely. Winter is one of my favorite times, the more snow the better. I’ve given up skiing, the Admiral worries about an old “F..t “ with old bones mixing it up with youngsters on the ski slopes. But she does enjoy snowmobiling. Within the neighborhood we maintain and groom several trails. Those trails connect to trails maintained by several of the local snowmobile clubs. We‘ve learned to dress warm and to enjoy our winters.Good morning Jan. It looks like you guys have plenty of clearing to do. That “jungle “ grows pretty rapidly during spring/ summer. Maine certainly (according to google) looks like a beautiful state. I don’t know how you guys do those crazy cold winters but a snowmobile sounds fun so better get those trails ready. Cheers Grant
Hmm. I doubt if any of the youngsters would stop texting long enough to learn how to do manual workI think the young ones still have a lot to learn from you.
Hi Jan, just remember that there has to be space for a beam to fit across the two doors. See below. Otherwise, the two door arches are going to sit out in the open.HOBOY!!THOSE PESKY DOORS!!!!!
I think I'm getting close. The Jan work around seems to be "OK", it passes my "four foot rule".
Jan
Hi Heinrich, I think I'll have just enough space above the doors to make that happen.Hi Jan, just remember that there has to be space for a beam to fit across the two doors. See below. Otherwise, the two door arches are going to sit out in the open.
Good evening Jan. Yep the 4 foot rule works for sure…. In fact a photo zoom also goes a pretty good jobHOBOY!!THOSE PESKY DOORS!!!!!
Jan
Hi Grant, I'm still diddling around with this part of the build. I managed to add door #2 and then dry fitted the clapboard planks between the doors. I tacked the planks on with Elmers Glue Stick. I'm trying to figure out how to space them properly. Yup, I just bumble along, fiddle with this and fiddle that until I'm satisfied.Good evening Jan. Yep the 4 foot rule works for sure…. In fact a photo zoom also goes a pretty good job. Cheers Grant
Your spacing looks absolutely fine, Jan. You should be good to go!Hi Grant, I'm still diddling around with this part of the build. I managed to add door #2 and then dry fitted the clapboard planks between the doors. I tacked the planks on with Elmers Glue Stick. I'm trying to figure out how to space them properly. Yup, I just bumble along, fiddle with this and fiddle that until I'm satisfied.
Jan
Hi Heinrich.Your spacing looks absolutely fine, Jan. You should be good to go!
