Yup, I made sure I did not get the planks wet. It is better to just wet the plank,like you said, rather then soaking it in warm water.
Very good. The very end of the thin strip that wraps around the bow on mine were made at an angle which needed to be cut to "respect the 5mm space for the stem" as noted in photo 17. I see yours are squared off. Did you cut them square or did they come that way?
Impressive. When I have had to bend plywood I have failed every time.
Good morning Frank. She is coming along extremely well. I’m with Paul and Allan, bending laminate generally splits with water as the glue is diluted - good thinking. Regular planks are way easier so no worries going forward. Cheers GrantI appreciate that, especially considering it was my first time ever doing it. To say I was a little nervous would be an understatement… I’m just hoping bending regular planks is much easier. At the rate it took me to bend those two pieces, I’ll be 6 months just planking the hull. LOL
Frank, it's coming along nicely! Good job! Magic Mike
Frank, sorry to hear about your bad luck. Are you using the hot iron to bend your planks? I'm in the process of building a wood steamer box & pin board to form my planks. I got the idea from Philski in the post "Bulkhead Filler Blocks" #46. I'll post photos later on but for now I'm doing some remodeling & organizing in the shop.
Frank, in case your interested here's the canon from Modelers Central compared to the kit canon. The canon mounting pins (if that's what their called) are a little farther back then the kits so I don't know if that will have an effect.View attachment 402490
If your talking about drilling out the end of the canon there is a nice bore hole in the ones I bought.Those look sharp for a buck-fifty!!! I’m working on cleaning one up & getting it drilled out to mock up a single cannon to see what I want to do as far as detailing/rigging. I might have to copy-cat you on that one just for the time savings alone…
