It is looking like a mass production - but we know, that every single frame is slightly different - you are on a fast and good way
Yes, each frame is unique, a work of art in itself.It is looking like a mass production - but we know, that every single frame is slightly different - you are on a fast and good way
Bought them in a hobby shop in Sweden. Not sure if they sell overseas.
mbs-rcmodels.se
Thanks for your attention. Yes, I have to be careful how the drill template fits. Will probably make it tighter. But now no major damage has been done. For one thing, there are a few margins to use and then it probably looks worse in the photo than in reality. Then the keelson will cover it all.I am not so sure, that drilling these bolt holes with a drilling template is a good idea
looking at the result the drilled holes are slightly at the wrong place or misalligned
I marked with red dotts, where the holes should be
The upper one is too close to the joint between the two half frames (one half frame is thinner than the other one, so therefore the hole should be a the center of the half frame
The other hole is to much at the center line of the keel so should be moved slightly to the left
I think, that such work is better and easier to control, when you see where your drill is
It is just a personal subjective suggestion by myself........
It run on all the time, but the frame was very time-consuming. But now progress is clearly seen as the ship grows.Now it is running - your work and progress is looking very good
We all know this feeling of creating the frames and installing them in such quantity that the hull of the ship is reflected from it, it is a feeling of satisfaction and pleasure.This is fun.View attachment 410095
Thanks, I'm glad to hear!We all know this feeling of creating the frames and installing them in such quantity that the hull of the ship is reflected from it, it is a feeling of satisfaction and pleasure.![]()
The frames you created look great and the installation work is very accurate![]()
