Hi. Does everyone secures their masts into the model hull just with some glue or some are using other methods? I imagine the rigging would hold the mast down but then how to prevent it from rotating around the axis?
... a bowsprit mast? Do you mean Foremast? Each mast has its own set of ratlines shrouds and backstays. All those rigging will secure masts good enough from rotating.The bowsprit mast has no shrouds to prevent it rotating around the axis. Is not it? Looks as it must be secured somehow.
1. You cut a square tenon {about an eighth to a quarter inch high}Hi. Does everyone secures their masts into the model hull just with some glue or some are using other methods? I imagine the rigging would hold the mast down but then how to prevent it from rotating around the axis?
