I was following here the well known modelHi Uwe, thanks again for your valuable input even I know all these images and info'sIt is good for others to have these here too. Thanks.
I will see which way I go
About your solution, with the nails here, quick disassembly does not work, because everything should be plugged in and just held inside by hooks and eyebolts.
cheers
Dirk
The parts which you mentioned was a frame, which was lifted by one piece. That was my understanding until now.
The model in the NMM made by Leigthly is presented with a frame box - I made my section identical
Other section models are showing such inner connections like you mentioned
I was thinking, that they had to lift also the heavier roof elements, so such a frame should be also not problem for some strong bodybuilderseamen - or lifting tackles with yard arms etc.
