Roter Löwe 1597 by Ondras71 - scala 1/60
Thank you very much for the responses. Yes, it was a lot of competition.Thumbs-Up And putting the work-in-progress model next to Vladimir's Le Gros model probably deprived me of points... :D
I finally finished the folded ribs of the boat..
Future rib height..
Sanded, I can lay boards..
Thank you very much everyone for the likes.
The most challenging part of a Dutch boat with a round bow and stern. Top board. Made stops to get the shape and cut the boards...
..bending into shape according to a paper template..o_O
First boards glued..
Bow..
Stern..
Finding? Very fragile. Tobias guessed!Thumbsup
I continue on the work boat. According to the plan, the boat has colorful decorations. I didn't want to do this on the boat, but the color strip will match the whole boat..
So spray paint white and then red triangles. The board is 2.2 mm..
Red...
And the resulting decorations..
I'm repainting and now just clean wood... Explosion
Piękna pracą. Pozdrawiam Mirek
Dear Ondras
merry Christmas and Happy new year :)
wonderful work as always Okay
Thank you very much friends, I appreciate your words.:)
I continue with the paneling boards, paper templates again..
Surfaces created on the ribs..
Gluing with long-term glue D3, fitting takes a long time..o_O
First board..
I wish modelers all over the world a lot of peace and time to build models in the new year 2024. Ondras
I continue on the work boat. Bending workshop..Explosion
According to the paper templates, I create more rows of boards, the edges highlighted with graphite..
The third row already has an extreme side bend. After a good soaking, the 0.8x3.5 mm strips can be bent well, just persistence. Step one - side bend..Sleep
Step 2 - after drying, bend into the shape of the torso, then fit.. I will save material against carving from wood plates..
The last part, closing the bottom. Too small, the bottom will not be visible, I helped myself by assembling the moldings from two parts. Otherwise, it would not be possible to do it well.. o_O
