HMS ALERT 1777 - 1:48 POF - Trident Model -by Stan
Very good progress, clean and accurate work -> Bravo looking very good
Wow, another "Madman" cutting his perfectly fine fully framed hull in half :p
But it will make a beautiful model. I like the way You cut out the planks "around" the deck beam ends. That is some accurate work!!
I see You did not have any trouble with the main deck beams being too short... so I definitely did something wrong.
AlI that I can think of to say is WOW!!!!! The only split model I have ever seen in up close in person is at Preble Hall in Annapolis and the construction amazed me then as your build amazes me now. THANK YOU for the pictures.
