    **VIEW RULES HERE**
Sussex 1693 navy board model
Hello everyone a quick update on the Sussex navy board model, I finished the limber strakes and I milled up some wood for the interior work,deck beams, upright posts, ledges, decking and more, I laid out the mortises for the gundeck clamps and milled them out on the mill, I also put a little steam to the front 2 to get the bend nice, I have made a little measuring jig for the gundeck beams and I have snapped a line down the center to keep everything centered, now I will be cutting deck beams and putting a finish on the bottom 1/4 of the ship, I will keep you posted along the way, thanks
Amazing work! All that milling consumes a lot of time. Nice job!
Bird,
I'm loving your build log. Your frame construction, clamping with the all-thread (see photo 1) and even the two frames that slightly separated (see photo 2) are exactly what I came up with/happened, for my 1st scratch build.
I look forward to following your solutions to all the inevitable issues that come up with a scratch build.
Very clean and accurate work - would be great to see more often some photos of your work - highly interesting
BTW: Now I know, why gunports are important - the clamps have to pass them ;)
Hello everyone I'm finally getting started on the Sussex, started resawing the cherry, I'm going to try to keep you posted along the way, I can't believe my little bandsaw works pretty good, I have a 14 inch in the garage that I am setting up, but just goes to show what is possible with small tools, set them up right & take your time & anything is possible..... hope you all have a great day
Hallo @Bird
Enjoy your special day
Hello everyone it's been a long time since my last update on the Sussex 1693 navy board model, I apologize for that,well I have made the upright posts that go under the gundeck beams and I have made some moldings from boxwood on the table router with a mini ball nose bit, I have finished the outer planking in cherry wood and have steam bent the upper whales also made from cherry and dyed black with black ink, and I have done both sides of the ship, I'm in the process of treenailing and the pencil sharpener works great, I am buying a dodge challenger rt in the next 2 weeks and this is so I can spend some quality time with my family and friends this summer and many more, I will keep everyone posted along the way, after my hiatus, thank you everyone...
Yes that is a cherry fence on my table router, I kind of invented the linear rail sliding fence, I still have to make a proper aluminum fence that is adjustable, but I think the sliding fence will come in handy doing miniature finger joints and things, LOL ..
Hello everyone it's been awhile since my last update on the Sussex 1693 navy board model, yes I'm still working on it only in the winter months!! I've put a finish coat on the inside of the hull up to the gundeck and started gluing in the gundeck beams with the pillars and have been working on the carlings and ledges, I started by cutting some stock 1/4 by 3/16 and then marked the gundeck beams for the mortises which I milled out on the sherline mill and then cut the carlings to length and cut the tenons and mortises in them on my mini table router and I'll be moving on to the ledges, riding bitts, grates, and some decking, I'll keep you posted along the way, thanks everyone ✌️
Fantastic carpentry!
Thanks!! I'm a little embarrassed by my fit and finish!! The lines did not come out as smoothly as I would have liked. I measured from the center line out, some will get covered with decking and grates
Likewise. I also ran a string down the centerline and used that to check things as I went along. It will all look fantastic as those very minor deviations will get lost in the overall view (please don't think I am comparing my little build to this majestic endeavor).
Yes I think you are right, the gundeck will get busy with things so your eye won't go right to it .
Scratch building at its finest! Thank you for sharing your wonderful model and techniques.
I love the color and grain of the wood after you oiled or stained it. Can you share what you used (both wood and stain)?
What a beautiful piece of work, as Paul has already mentioned I think that this small deviation will not be visible over time. I really like the color, very nice warm wood, I suspect pear. I correct it, it is cherry.
Thank you!!! It's mostly built from this solid piece of cherry wood and I went with this antique oil finish, it got really good reviews and is a (hard finish) when I was doing research on what to use hard finish oil was the way to go for reasons that I've forgot, but I really like it!! 2 coats will give you a dull sheen.
