I continue to be impressed with the quality of your work, Mark. This is just very, very fine modeling!
			|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Nice informative post about the use of the deadeyes and chainplates, Mark. They are nicely aligned.Channels, chainplates and deadeyes. The sets of channels are painted dull black and attached to the sheer rails on either side with headless nails and glue. Strips of natural walnut are used to trim each channel edge and effectively seal the openings that will accommodate the deadeyes. The three masts are stepped temporarily and rope threads from the topmasts are used to emulate the shroud lines and determine the angle with which to attach the chainplates to the hull below.
Amati provides a very nice set of brass links with which to assemble the chainplates and the upgrade kit also came with improved strops for the deadeyes. Blackening all the brass bits isn't much fun at the best of times but I did at least heed the kit's inspired advice to blacken them in place in the template rather than remove and paint them all individually.
The kit-supplied 5mm deadeyes seemed far too big for this assembly and I used 5mm deadeyes that I had purchased from Dry Dock previously instead. These looked a lot better and, interestingly, were a far better fit for the strops supplied in the upgrade kit. The smaller, 3mm deadeyes and strops supplied in the kit were just fine.
As mentioned earlier, the Amati's chainplate links are well designed and fit very snugly together. For instance, the ends of the preventer plate and loop link that receive the upper bolt are both recessed to make the connection seamless and flush with the hull. However, care must be taken to position the channels accurately; some of the chainplates came perilously close to gunports, row ports and port lids
It is yet to be seen whether the angle of each chainplate will match the eventual angle of the corresponding shroud line. Holding thumbs on that one. All in all, the channel and chainplate installation was a fun exercise. The only issue was making sure that the preventer plate bolts do not interfere with anything inside the hull. Some of the bolts came very, very close to the gun-rigging ring bolts on the hull interior. A miss, however, was as good as a mile
Thanks for checking in
Mark
An extraordinal well built. A lot better accessories are now available today -not in my time - but expect too, that this will influence the final price. Anyway again an extraordinary buildChannels, chainplates and deadeyes. The sets of channels are painted dull black and attached to the sheer rails on either side with headless nails and glue. Strips of natural walnut are used to trim each channel edge and effectively seal the openings that will accommodate the deadeyes. The three masts are stepped temporarily and rope threads from the topmasts are used to emulate the shroud lines and determine the angle with which to attach the chainplates to the hull below.
Mark
I fully agree.very accurate work - Very good
Mark, every update just further complements all your previous work!The upper quarterdeck rails run the full length of the quarterdeck at a gentle but ever-increasing angle to the capping rails below. They are supported by a host of swivel gun posts and each have a belaying pin-rack installed aft. The drift rail on the hull exterior forms a baseline for all the swivel gun posts, which are in turn notched to accommodate the upper quarterdeck rails. Getting the drift rail positioned properly goes a long way to ensuring the accurate alignment of the upper rails.
The swivel guns are blackened and inserted into receiving holes drilled into the top of each swivel gun post. They are only dry fitted at this stage. Sixteen swivel guns adds another sixteen snag-magnet opportunities to the hull, so they will be removed and re-installed in the posts at a later stage.
The ship is fitted with enough armoury to fight a battle, if only she could sail! Next up will be the channels, chainplates and deadeyes in preparation for the rigging that is to come.
Mark
In my case I did NOT INSTALL the swivelMark, every update just further complements all your previous work!
Good morning Mark. Wow you are owning this HMS Fly. Cheers GrantChannels, chainplates and deadeyes. The sets of channels are painted dull black and attached to the sheer rails on either side with headless nails and glue. Strips of natural walnut are used to trim each channel edge and effectively seal the openings that will accommodate the deadeyes. The three masts are stepped temporarily and rope threads from the topmasts are used to emulate the shroud lines and determine the angle with which to attach the chainplates to the hull below.
Mark
absolutely beautiful !The hull of my HMS Fly is finally on its short final approach towards completion. There were just a few bits and bobs left to install, or at least prepare for later installation. The side steps, for instance, each received a pair of handy guideropes...
Belaying pins and racks were installed on the quarterdeck...
A pair of boomkins to extend from the bow and, of course, a lovely figurehead to adorn the prow...
... and finally a set of anchors that will be rigged on the fore channels later in the build.
The kit suggests that the estimated build time for the HMS Fly is 'between 100 to 120 hours'. I'm not sure whether to laugh or cry. It has taken me this long to finish her hull and fittings and I can't imagine that the rigging effort will be any quicker.
It is, after all, all about the journey
Mark
Mark, good job.The hull of my HMS Fly is finally on its short final approach towards completion. There were just a few bits and bobs left to install, or at least prepare for later installation. The side steps, for instance, each received a pair of handy guideropes...
Mark
Good afternoon Mark. It is so good.The hull of my HMS Fly is finally on its short final approach towards completion. There were just a few bits and bobs left to install, or at least prepare for later installation. The side steps, for instance, each received a pair of handy guideropes...
Mark
