Here is another article knowledge about the boxwood (real boxwood)
https://en.wikipedia.org/wiki/Buxus
no,they are not ,not even closeI have a question. Is limewood the same thing as boxwood? I see in certain kits that they use limewood instead of boxwood and it almost sounds like they are the same thing?
i wonder why they make this substitution?no,they are not ,not even close
Jack, I think it is a typo with Boxwood, it probably said Basswood.have a question. Is limewood the same thing as boxwood? I see in certain kits that they use limewood instead of boxwood and it almost sounds like they are the same thing?
My bad. you are correct. I seem to get boxwood and basswood mixed upJack, I think it is a typo with Boxwood, it probably said Basswood.
Limewood (also known as basswood) is the most popular type of wood for carving. Whether you're a complete beginner or a member of the carving elite, this species should be near the top of your list. Extremely soft and crisp, lime wood is perfect for intricate carving and works exceptionally well with hand tools.
I got mixed up basswood and boxwood. sorry about thatno,they are not ,not even close
The English and Europeans in general use Lime. The limewood has a grainier, darker, more iridescent quality than Boxwood. I'we used the lime strips I got in European kits for deck planks. I was very happy with the way it finished and its depth of color.
In Canada it is a shrub too, from what I have read.with the boxwood we will open, yet another Pandora box. The boxwood in Russian Букс or Cамшит is an evergreen shrub or small tree, it is rather a bush instead.
It is very hard (like metal), and yellowish.
What kind of wood did you use for the frames? I'm having a problem with that right now and don't know what is best to use. NorgaleThis was a hard learned lesson in color changing. This is a model hull of the Great Lakes bulk carrier Argo.
it is an old photo and the color is faded but it demonstrates what happens to wood over time or cutting the same plank of wood a year later.
The colored arrows are pointing to section of the hull built over different times. The front section was built first and the wood ages darker then the light green arrow at the stern. The darker blue arrow is the same framing stock cut about a year later. Wood cut at different times do not "catch up" to the older wood. As the newer framing stock is aging darker the older framing stock is also aging darker at the darker green arrow at the bow section.
if you are going to frame up a hull it is best to cut ALL the framing stock at the same time or you will end up with color zones in the hull. The deadwood at the stern is the same wood as the frames at the bow just cut much later in the build.
color will also vary as in the last post so if you start a project and maybe 6 months or year later and you reorder more wood, maybe you will get the same color as before OR maybe not and it will not match what you have already done.
