A fun addition Mustafa! Well done!
**VIEW THREAD HERE** |
A very interesting document, Uwe. Thank you for sharing.maybe interesting to read for you
Through the Hawse Hole - USS Constitution Museum
Join us on July 23, as we celebrate “Old Ironsides’” much-anticipated return to the water! On that night, Dry Dock 1 will be filled and USS Constitution will. . .ussconstitutionmuseum.org
The photograph below, taken on November 11, 1974, after Constitution had been refloated from Dry Dock 1 in the Charlestown Navy Yard, shows what appears to be a Navy Yard worker (in the hard hat with number “63”) installing an inner flange on the port hawse pipes. The cast iron hawse pipes are, essentially, sleeves that fit into the holes cut through the three layers of oak that make up Constitution‘s hull structure. The outboard flange is cast to the body of the hawse pipe. However, there is no inboard flange cast to the pipe body, which may be one reason the 1971 drawing was made. At that time, in the early 1970s, it may have been determined that the hawse pipes needed to have inner flanges that could be through-bolted to the outer flange, thereby locking the hawse pipe securely into the ship’s bow.
Charlestown Navy Yard workers on USS Constitution’s gun deck, November 11, 1974. The worker in the hard hat may be setting an inner hawse pipe flange in place. [Courtesy Naval History & Heritage Command Detachment Boston]
Thank you Paul. I love dealing with details.A fun addition Mustafa! Well done!
Thank you. Since I will partially plank the spar deck, the details on the gun deck will be visible at least slightly.Great job. It is always the little things that make your model stand out.
Thank you for your interest, Peter. I would be happy if I could contribute to my friends.Ivery much enjoy following your build and your evolving process. I find it very instructive and helpful to my own process.
Thank you very much Marc. Your craftmanship is actually better than mine. I believe that if you had the necessary machinery, you could do much better work than me.It's simply amazing... fantastic details...
How on earth do you make this so nice....
I do not consider myself at the level of mastery, this would be unfair to real masters, But I am good at copying.This build is really kind of like a masterclass-tutorial on woodworking for modelers.![]()
Pete
Thank you again for your nice thoughts. It's an honor to hear these from a master like you.Mastery is not something that appears fully formed, like Athena from the mind of Zeus. It kind of creeps up on you after years of practice so you hardly notice. It begins with a sincere appreciation of what it is you're working on. You clearly have that.
So, it's no wonder that you're surprised when others take notice of your accomplishment, having caught you unaware, as it were.
I've spent my working life around examples of fine woodworking spanning several centuries. (I had the good luck of walking into the right antique furniture dealer in the right place at the right time around 1980 and they gave me a chance, liked what they saw, and put me to work.) So please accept my sincere appreciation of your skills.
Pete
