Canoe21
Lawrence
Hello Shota, Thank you for your good wishes, I believe that I will need them when I start stacking the frames.Dear Lawrence
good luck with your new project,I will keep following with great curiosity![]()
Regards Lawrence
Hello Paul, Thanks for your comments, yes the but joints do have me a bit worried, but that is a ways off yet.Hmm. Butt joints on the frames. That will require some precision sanding Lawrence! Looks like your off to a great start!
Hello Henrich, Thank for your vote of confidence, yes this part is rather easy it just takes a fair bit of time.That looks very well executed, Lawrence - neat and precise. Experience is a wonderful thing especially when it comes to "scratch" POF builds.
Hello Shota, Thank you for your very kind words and comments. This cleaning and gluing on the templates is coming to an end, the end is in sight.Dear Lawrence
Hello Spree Three, I thank you for visit to my HMY Fubbs build log. I have built the HMS bounty and also the Oliver Cromwell from scratch for build on frame . Sawed and planed my own lumber in our basement creating tons of saw dust and shavings. This HMY Fubbs stern section most of that work has already been by Mike Shanks. So my build is moving along much faster then previous builds. But I still have to clean up and taper all of these frames before I can start to assemble this beautiful fine little ship stern section.Hi canoe21 - you are making great progress - I am following WJ Romero practicum - 2020 lockdown gave me 3 months to cut the frames from scratch - tedious but...the end result will always bring a smile.
Good to see you making sawdust Lawrence, from what I've seen these scratch / kit's make up into a really nice model,Hello Spree Three, I thank you for visit to my HMY Fubbs build log. I have built the HMS bounty and also the Oliver Cromwell from scratch for build on frame . Sawed and planed my own lumber in our basement creating tons of saw dust and shavings. This HMY Fubbs stern section most of that work has already been by Mike Shanks. So my build is moving along much faster then previous builds. But I still have to clean up and taper all of these frames before I can start to assemble this beautiful fine little ship stern section.
Regards Lawrence
Hello John, Thanks for your very nice words and comments. Yes this is a great ,I choose the hard maple wood version, it is machine cut from 1/2" or 1271mm at the 1:24 scale. I am on my last batch of cleaning up the hull frames and gluing on the templates so as to be able to flayer the hull. That should start in the next day or so.Good to see you making sawdust Lawrence, from what I've seen these scratch / kit's make up into a really nice model,
Best regards John,
Hello Daniel, Welcome to my build log on the HMY Fubbs. It is nice to have you on board.Hi Lawrence , here I am following your progress too. Soon I will be returning to my build again.
Best !!
Daniel
Hello Paul, Thanks for your kind words, tomorrow we will start the hull flaring and make lots of dust. Regards LawrenceNice clean work Lawrence!
Hello Don, Thanks for your very kind words and nice comments. Yes you are correct the cherry version is a little easier to start but then it becomes all the some. Do hurry back to your HMY Fubbs, will be waiting to see all of your pictures.HI LAWRENCE GREAT TO SEE YOUR FUBBS I AM SOON RETURNING TO MINE, HAVE COMPLETED MY FIRST STACK WILL CONTINUE ON MY LOG. NO TEXT JUST PICTURES OTHERS ARE MUCH MORE CAPABLE THEN IN EXPLANING I HAVE THE CHERRY VERSION DO NOT HAVE TO USE TEMPLATES LIKE JODIE AND DOC BLAKE. GOD BLESS STAY SAFE YOU AND YOURS DON
Good morning Lawrence. Looking spot on . I hear Paul re those butt joints- something to look forward to….Cheers GrantHello Ship Mates, Well today the little fellows and I completed the clean up the rest of the hull frames and glued on there temp plates. I still do have an issue with frame #36A and am waiting to here back from Mike to see if I have chosen the right correction. So tomorrow we will start the to taper the hull forms.
Regards Lawrence
