Heinrich, that sounds interesting. That would be an great piece of history to display. The WB on completion has found a home in Northern Maine, while the Duyfken will sail to a home in Massachusetts once it's completed. Both ships will still be in the "Family" just docked in different ports.Jan, come to think of it. According to @Kolderstok Hans, the Halve Maen is on the list of future Kolderstok models. That ship is a no-brainer for you to build as it was instrumental in establishing the Dutch settlers at Maine. I just read another article about the Dutch at the North Pole and at Maine, highlighting the roles of Barentsz and Henry Hudson.
Eish. Good morning Jan. It doesn’t look so bad in the previous photo… Ah well nothing like redo’s. Cheers Grant@Heinrich
The unexpected bits that pop up during a build.
I had a good chuckle this morning, weeks after building the lower and upper decks adding all the above deck paraphanalia , paying close attention to the instructions plans, your and Piets WB logs, I find that I build in a minor flaw on my WB.
It's hardly noticeable but does need a fix.
The Fore Mast fit was good, the Main Mast seated well in the holes of the upper and lower decks.
BUT the Mizzen Mast deck holes don't line up. Two out of three aren't bad??Right??
Yup, a good chuckle. this morning. Takes me back to five gunports on the Starboard side and six on the Port. Just another step in the Jan WB build process.
Jan
Hi Grant. That photo was a "Test" fit and I had placed the Mizzen and Main mast to see how they aligned with the Fore mast. I just popped them into the holes on the deck. The error in alignment showed up when I set and glued the Main Mast. While wiggling that mast into place it dropped neatly into the hole in the lower deck. That was the "AHA, EUREKA" moment. I'd completely forgotten about the lower deck mast holes. Long story short, I wiggled, twisted, turned, etc. the Mizzen mast until it dropped into the lower deck hole.Eish. Good morning Jan. It doesn’t look so bad in the previous photo… Ah well nothing like redo’s. Cheers Grant
From the looks of that thing it might have been easier to move the house...Very good Jan however, it may have been easier to move if you would have taken the ice out first.
Sorry, couldn't resist
Geez I wish I had thought about that.Very good Jan however, it may have been easier to move if you would have taken the ice out first.
Indeed, that thing is massive. It's held down that corner of the room for 25+ years.From the looks of that thing it might have been easier to move the house...
That alignment looks much better, Jan.Furniture moving Intermission:
Setting the Mizzen Mast.
I decided against Plan A, ie. drilling a new hole in the sub deck. Plan B is/ was to add a small nail (about 3mm long) to the bottom of the Mizzen mast, smear on PVA, align the mast as best as can be, give it a sharp tap with my hammer and hope for the best.
I think the result is well within the "Four Foot Rule".
Jan
Yessir, I need a lot of energy to put that "thing" back. Hopefully as Ron indicated all the "ICE" will have melted and it will move a lot easier.set the Monster back on his place
Hi Heinrich. I never thought about a connection between our Icebox and the history of the WB, good point. The WB traveled North and encountered the icepack while over the years our Icebox has traveled from the far North of the state to our house in the South (almost 400 miles). This summer it will be passed on to another family member and travel to West coast (about 3300 miles). Not bad for a piece furniture build in the early 1900's.Ice boxes and the WB's mizzen mast. There is a sinister correlation there as an "icebox" is exactly what caused the ultimate demise of the WB! You have just lent a macabre historical accuracy to your build, Jan.
Perhaps you leave the monster where it is, that is easyer for the next move this summer.This summer it will be passed on to another family member and travel to West coast (about 3300 miles)
The monster is now much closer to the front door, as a matter of fact it’s right next to the front door. Ready for the next leg of it’s journeyPerhaps you leave the monster where it is, that is easyer for the next move this summer.
Guess you found all your marbles again...Indeed, that thing is massive. It's held down that corner of the room for 25+ years.
Jan
Could you please expand a little on that correlation?Ice boxes and the WB's mizzen mast. There is a sinister correlation there as an "icebox" is exactly what caused the ultimate demise of the WB! You have just lent a macabre historical accuracy to your build, Jan.
